radiator help
Old Dec 15, 2009 | 07:54 PM
mitcho168's Avatar
mitcho168 is infamous around these parts
Exclamation radiator help
2004 996 turbo covertible hi i found out i have a small radiator leak on the passenger side. aww not good. do you guys know what i have to take out to raplace the radiator any diy ? thanks and where would i get the best deal on a radiator is there any aftermarket ones? for a good price. thanksplease help thanks guys
Old Dec 15, 2009 | 07:59 PM
REVS11's Avatar
REVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond repute
Best deal prob Ebay, make sure you get the correct side since left right are not the same.
Easy job. Remove bumper skin then you have access, you may have to remove some plastic fender lining as well on that side. Three hoses and a few small screws to release the kondenser in front of it, then the radiator sits with three clamp type washer looking things.
Bleeding afterwards will be where you have to be patient and careful with engine temp.
Old Dec 15, 2009 | 08:17 PM
mitcho168's Avatar
thank you is there a bleeding procedure?
Glasgo
Nov 30, 2015 02:37 PM
White991TT
Oct 25, 2015 12:29 PM
bongnation
Sep 25, 2015 02:58 PM
markj
Sep 20, 2015 04:19 PM
