Need Help!! My Check engine light came on. Error Code P1109.
Old Dec 29, 2009 | 10:54 PM
ggarza007's Avatar
ggarza007 is infamous around these parts
I have a 2004 996TT. My check engine light came on. The error code read P1109. What does this mean? What could be causing this? Thanks.
Old Dec 30, 2009 | 07:55 AM
fdorn's Avatar
fdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud of
P1109 Input variables, charge measurement - above limit
Possible fault cause
- Heavily soiled throttle
- Throttle adjusting unit faulty
- Mass air flow sensor faulty
Clean MAF - Suggested below
https://www.6speedonline.com/forums/...about-diy.html
Old Dec 30, 2009 | 08:00 AM
ShokWaveRider's Avatar
ShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to all
Here you go: Looks like a MAF. Did you recently install a NEW "Oily" Air Filter?
I would try at least cleaning the MAF First.
P1109:
Points to:
1) Heavily Soiled Throttle
2) Throttle Adjusting Unit Faulty
3) Bad MAF.
SWR
Old Dec 30, 2009 | 04:04 PM
ggarza007's Avatar
Thanks for your help. I have the Hitachi MAF. It was installed about 6 months ago. I am going to clean it. What do you guys recommend that I use to clean it. Thanks
Old Dec 30, 2009 | 05:27 PM
fdorn's Avatar
Not sure if all the pics are still there, but this is what I used.
https://www.6speedonline.com/forums/...-cleaning.html
tropicatango
Jun 8, 2025 01:00 PM
Mini George
Jul 29, 2019 12:20 PM
Jul 29, 2019 11:13 AM
Mini George
Jan 18, 2016 09:16 PM
