Rear Spoiler Problem
Old Jan 6, 2010 | 12:54 PM
RAU940's Avatar
RAU940 is infamous around these parts
I agree this is probably the issue.
Originally Posted by calfrank
I have the same problem as well. Been like this for 3 months now. It goes up and down, but it throws the spoiler failure control warning light. I've done some research and people recommend changing the spoiler switches. Not sure if that's the actual problem. Dealer wanted $60 bux for each switch and we would need two of them.
The switches are on the right side, attached to the right tube, very small switches.
The whole idea of a movable wing is dumb, should just be fixed like a GT3.
Old Jan 17, 2013 | 06:53 PM
VGLNTE1's Avatar
VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !
Subscribed
Old Jan 18, 2013 | 12:19 AM
S4corrado996TT's Avatar
S4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really nice
Subscribed! Tks for sharing!
Old Jan 18, 2013 | 07:25 AM
#9shooter's Avatar
#9shooter has a spectacular aura about#9shooter has a spectacular aura about#9shooter has a spectacular aura about
Thanks for the info i am having the same issue and my left ram has fluid leaking i rather give it a shot and if it doesnt work off to the dealer
thanks for the post asgor
Old Jan 18, 2013 | 09:52 AM
Gunther's Avatar
Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !
A complete system bleed does wonders to fix the problem. At least it did on my car.
Old Mar 3, 2013 | 02:00 PM
jpflip's Avatar
I was navigating on the net and found a place that overhaul the spoiler system...Anybody ever tried them?
http://cabriolethydraulics.com/porsc...hydraulics.php
Old Mar 7, 2013 | 10:18 AM
Mr. C4's Avatar
Mr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to behold
Fantastic! Have they sent you a quote?
Old Mar 7, 2013 | 11:57 AM
cburke996's Avatar
cburke996 is a glorious beacon of lightcburke996 is a glorious beacon of lightcburke996 is a glorious beacon of lightcburke996 is a glorious beacon of lightcburke996 is a glorious beacon of lightcburke996 is a glorious beacon of light
They charge $600. You send them the complete system (rams, pump, lines) and the rebuild it and fill it with new fluid. I believe they give it a 3 year warranty as well.
Old Mar 7, 2013 | 01:01 PM
Mr. C4's Avatar
Do you know if they ship internationally?
Old Mar 7, 2013 | 03:03 PM
cburke996's Avatar
No im not sure.
Old Mar 7, 2013 | 11:10 PM
#9shooter's Avatar
i gave up fixing it and just locked it in up position and disconnected the switches no light anymore
Old Mar 8, 2013 | 12:40 AM
Terminator's Avatar
Terminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant future
My friend had a leaky ram actually, he had a pissing ram. That got me into checking my rams. I’ve noticed a slight leak on one of my rams. Because rams are covered by this plastic protection cap, no one looks under there. I discovered that the bolt at the bottom of the ram had worked itself slightly lose, my guess is from the vibrations. I retightened the bolt and the leak stopped. So, I suggest all of you with working spoilers, check those bolts for some preventative maintenance.
Old Mar 8, 2013 | 07:27 AM
XLR82XS's Avatar
Great advice.
Old Mar 8, 2013 | 07:51 AM
Darthvader's Avatar
Darthvader Is a GOD !Darthvader Is a GOD !Darthvader Is a GOD !Darthvader Is a GOD !Darthvader Is a GOD !Darthvader Is a GOD !Darthvader Is a GOD !Darthvader Is a GOD !Darthvader Is a GOD !Darthvader Is a GOD !Darthvader Is a GOD !
I disabled mine and went with a fixed wing kit. If the next owner wants to reverse it they can.
Old Mar 8, 2013 | 03:45 PM
Hams996TT's Avatar
Hams996TT is infamous around these partsHams996TT is infamous around these parts
Thumbs up
Thank YOU for the link kind sir.
While my car's rams are perfectly operational, this is a cheaper alternative to a new replacement system from Porsche.
Thanks again!
Chris.
