GT 28's Info/ Advice
Old Feb 20, 2010 | 10:34 AM
MBailey's Avatar
Originally Posted by 911 RV
Any othe way to I.D. these turbos. Do you know the inlet ands outlet size. I could measure with micrometer in MM. Any other typical markings. Is the water cooling journals typical on Alpha 28's, or more common in general of most aftermarket turbos.
Just want to learn.
Ron
Sorry Ron don't know those numbers. The water cooling holes are present on A28s for sure. Not sure if that positively identifies them though.
Old Feb 20, 2010 | 10:43 AM
LamboTT's Avatar
LamboTT has a spectacular aura aboutLamboTT has a spectacular aura about
There a couple different variations of the GT28's from what I understand. I have the gt28/with the K series exhaust housing but it uses the whole center section of the GT28 including boring out the turbine housing. Mine is also ball bearing with the water cooled option. I just put them on and they seem to be spooling faster than the stock K16 turbos with a flash I just took off.
Old Feb 20, 2010 | 10:53 AM
911 RV's Avatar
911 RV is infamous around these parts
So do you know on your exhaust side, what if any identification marks are on them. If you could look that would be great. Just dont know what markings/ ID a stock k16 hotside comes with.
Ron
Old Feb 20, 2010 | 11:01 AM
Neil Switzer's Avatar
Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !
Here's how our p800 setup does on the rollers:
That is with our custom A28 turbos on 93 pump gas, stock airbox/intake pipe with drop in filter, our full exhaust with 200 cell cats, Our 6" Monster IC's and hose kit.
Spool is faster than stock k16's and makes 30r-like power on the top end.
Click the link in my sig for more information...
Old Feb 20, 2010 | 11:07 AM
911 RV's Avatar
Neil, any pics of your A 28's off the car you could post and or closeups installed. Just would like to compare.
Thanks,
Ron
Old Feb 20, 2010 | 11:28 AM
MBailey's Avatar
Ron
Ron,
I doubt your turbos have a K-16 hotside since they are in a Tial housing. However, the A28s apparently come in several flavors as well. I have not been able to find out any detail about this as most tuners are somewhat secretive about their individual variants. I have been told the A28s from Switzer, EVOMS, EPL, ect... are all different.
Old Feb 20, 2010 | 11:49 AM
911 RV's Avatar
Yea, I was on the Tial website and you are correct, they have several variations. Mine do look like the A28s on their webiste pics with the billet actuator ect. My compressor side has the Garrett lettering as in the pics. Their hot side was not clearly labled so I could not do a comparison where mine have a cast in "Tial" showing. I guess I need to call EVOMS as that is small stamped on the flat emboss on the compressor side.
I did not know there were so many versions.
Ron
Old Feb 20, 2010 | 12:14 PM
MBailey's Avatar
Ron
Those sound identical to mine.
Old Feb 20, 2010 | 12:27 PM
flash68's Avatar
flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !
Mike do you have the newest version of the alpha 28s? When did you get those turbos you have on now?
Old Feb 20, 2010 | 12:42 PM
MBailey's Avatar
I dont think so Dave. I got them in May 2008.
Old Feb 20, 2010 | 01:19 PM
flash68's Avatar
Hell, it's not like any of us actually know what we have anyway!
All I know is that your turbos obviously work very very well for you!
Old Feb 20, 2010 | 01:22 PM
ttboost's Avatar
Can't you call Autotalent, won't they know what they put on the car?
Old Feb 20, 2010 | 01:23 PM
ttboost's Avatar
I'm pretty sure I know what I have...
Old Feb 20, 2010 | 01:43 PM
flash68's Avatar
Of course I meant the secretive world of Alpha and Tial that some of us live in
Old Feb 20, 2010 | 02:49 PM
yllwturbo's Avatar
yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !
maybe its better if u can take some pictures n post them.
