AMS Billet K16 1st Track test
Wow 127 mph is moving for K16's! Your leaving alot on the table with those 1.9x 60 foot times! With enough traction you could probably break in the high 10's or at least very low 11's.
Here is a video of my run against a Nissan GTR (forward to 3min.27 sec),my car has K16/24, FVD tune for 1 bar,europipe exhaust,blizzard IC's and my speed trap is : 211.14km/u (131.19 miles). So I think at 1.3 bar you should do better than me.
http://www.youtube.com/watch?v=8OBYiaYUVeY
I ran 11.65 @ 126 with stock K16s, intake, exhaust and tune...at only 1.1 BAR (AWD, full-weight).
At 1.3 BAR with K24/18Gs, I ran 10.65 @ 136 (RWD conversion).
Regardless, nice job Beltfed. Your car is running very well on snow tires.
My car ran 11.5 -11.7 consistently and trapped 126-127 consistently with K16/24 hybrids, full exhaust, flash and AWD. No other mods - about 1.2-1.3 bar boost. With the higher boost being run today (that was about 4 years ago), I think the K16/24's could trap even higher, if pushed.
http://videos.streetfire.net/video/e...4a01788977.htm
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
2022 Cayenne White
Since it still uses a k16 hot side, you shouldn't see much difference at these "lower" boost levels between AMS's billet wheel and the other conventional k16 hybrids. The advantage of the billet wheel is less inertia (faster spool), higher max airflow capacity, and better efficiency at higher pressure ratios. You won't see much difference in trap speeds at these low boost levels.
The k24/18s will make slightly more power at lower boost levels due to the larger hot side, as well as having a higher airflow capability that the non billet k16 hybrids.
