PSM / Airbag Light came on ...
I know this issue has been beaten like a dead horse ... but I need some enlightment and wisdom from y'all ...
I was driving on the freeway ... I hear a very slight swishing noise coming from the rear right area as I accelerate (approx 100 - 120 kph / 75mph) ... so I figured maybe a loose hose clamp .. some boost leak perhaps ...
Then I exit when I get closer to my destination ... then PSM / Airbag lights dings with SOLID yellows ....
I park when I get to the destination (no limp mode or anything) ...
I do the customary 1-2 cooldown ... the car's tach needle goes up and down from 500 - 1500 as it tries to idle ....
I figured its the MAF this time ... but the service record says that it has had a new MAF back in October ... and another one in January ...
So, maybe it couldnt be the MAF??!! If it is indeed the MAF, what's causing all the failures?
Its an 04 STOCK ... I had an 02 X50 that had EP2GL + UMW 2ZC 16/24 without any MAF issues whatsoever ....
So, what gives?
So, what gives?
LiquidElephant
Aug 27, 2015 06:17 PM
GSR Autosport
Aug 26, 2015 05:20 PM
pwdrhound
Aug 23, 2015 07:36 PM
Walorus
Aug 18, 2015 01:39 PM
