Some disturbing news.
Old Apr 15, 2010 | 11:06 AM
Prche951's Avatar
Originally Posted by Mad Ness
same here heard of 2 997tt mk2's low miles, bone stock, had engines replaced under warranty. i had just assumed it was maintenance related ie not topping up oil etc.
I have heard of these problems for sometime, but have seen it at the local dealer twice in a year. And I forgot about another one at a local shop that it's engine replaced for similar reasons in his boxster. then I have heard of these engines going well over 100k with no problems. To much inconsistency for me. I hope they ironed out these problems for the 09-2010 NA cars. Seems like Porsche did put a lot of engineering into the new engine, and maybe they are just letting it get street tested to iron out any issues that come up prior to introducing it into the racing series.
Old Apr 15, 2010 | 12:15 PM
topgun's Avatar
topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !
It's the other way around, they race it then it trickles down to the street applications... (most of the time anyway)
Old Apr 15, 2010 | 12:23 PM
Prche951's Avatar
I know, but I am being hopeful in this case
Old Apr 15, 2010 | 01:28 PM
germeezy1's Avatar
germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !
Well Porsche did bring in retired Toyota engineers to help with its production processes but that was during 996 development.
Old Apr 15, 2010 | 03:42 PM
rdss's Avatar
rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !
I will keep my 996tt forever...............and heavy modded
Old Apr 15, 2010 | 04:47 PM
dtakenname's Avatar
dtakenname is infamous around these parts
Originally Posted by PeterK
The new turbo engine is basically the turbo-charged version of the DI, 3.8L engine you get on a carrera S. So, yes it is very different from the classical split design of the 3.6l engine. It is also lighter and much less complex.
Hi,
So, is the new DFI, 3.8L engine on carrera S, got the same crankshaft and bearings of the DFI turbo engine?
Many Thanks.
Old Apr 15, 2010 | 05:03 PM
PeterK's Avatar
PeterK is infamous around these parts
Originally Posted by dtakenname
Hi,
Many Thanks.
Now these details I don't you. Whatever I know, I learned from the automotive press releases and such.
Are there many instance where these parts fail? I've driven the new DI S car with PDK and it felt very strong.
Old Apr 15, 2010 | 05:11 PM
Prche951's Avatar
Hi,
Many Thanks.
Doubtful, that they integrated the turbo engines upgrades into the NA cars, when they aren't putting down the extra torque. They never did it in the past, why do it now. But who knows. It is more likely that they integrated the NA car engines internals to the turbo. Hence why everyone is complaining. The new engine weighs considerably less than the older version in the NA cars and less than the GT1 engine. to bad they couldn't add the weight back in an iron case
Old Apr 15, 2010 | 05:53 PM
skandalis447's Avatar
skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !
I am 100% sure that porsche manufactured this new motor with very high reliability factors in mind...however this statement is only for stock motors...new 997.2TT is a miracle in automotive engineering...if only it had Mezger engine...
997.2TT engine has a wet sump...so the engine is a little taller than before...And porsche engineers had to raise rear suspension a few mm in order to maximize oil pan clearance from road...
Old Apr 15, 2010 | 07:26 PM
cjv's Avatar
cjv
Moderator
Hi,
Many Thanks.
No. I have been told by Scargo Racing that most of the parts are different.
If they are not using this motor in the GT3 it isn't as good. Before the main difference was the heads, valve train, same crank except is was forged and oil pump.
Old Apr 15, 2010 | 09:03 PM
germeezy1's Avatar
In their literature it sounds like they wanted the throttle response of the port injected engine. I know until recently there were issue with extremely high revving DI engine but of course now that issue has been solved. I wonder what they gained by going to the A91 from the Metzger motors?
Old Apr 15, 2010 | 09:36 PM
bbywu's Avatar
About $25K a motor.
Old Apr 15, 2010 | 09:41 PM
TT Gasman's Avatar
TT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant future
^^^^^^Bingo!
Prche951's Avatar
Originally Posted by bbywu
About $25K a motor.
and they increased the sticker on the car. Gotta admit though the pdk does cost more than manual trans.
Old Apr 15, 2010 | 09:50 PM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
Originally Posted by Nikolas
Maybe I'm off, but from what I have seen the 993TT has a much better resale value history than the 996TT. Right now many are priced higher than 996TT's in similar condition/miles.
That is my point. 993TT prices skyrocketed after the 996TT came out, even though the motor is the same with water cooled heads. I think the same will happen to 996TT and esp the 997.1TT after the 997.2TT comes out. The production of 993TT were limited as with every other previous Turbo models due to limited split case engine production which had to supply all 993 models at the time. When the 996 NA engine came out, and production of it was outsourced, production capacity of the split case engine was no longer a limitation and Porsche could pump out as many 996TT as the market would absorb. It also allowed them to build more GT3/GT3RS/and GT2 models.
