1/4 mile drag tire question
Old Apr 19, 2010 | 04:34 PM
Gsxryder415's Avatar
Gsxryder415 is infamous around these parts
I am planning to run some drag radials on my 996 TT at the drag strip and was planning to just run the drag radials in the rear. Just wanted to get some thoughts on whether just running the drag radials in the rear would be fine and also for you drag guys out there what your tires set up are. Any info would be great. Thanks!
Old Apr 19, 2010 | 04:44 PM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
be careful that the DR's aren't taller than the front tires. both front and rear need to be very close in diameter or you run the risk of ruining the front diff.
Old Apr 19, 2010 | 04:47 PM
that is a good point.
is it ok to run a drag radial in the rear and a regular tire in the front if the car is still AWD?
#TeamAIM
Old Apr 19, 2010 | 04:48 PM
No, you must run in RWD
Old Apr 19, 2010 | 05:01 PM
onelove's Avatar
onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !
If you're going to run Drag radials definitely want RWD. You'll want to get some heat i the tires prior to making a run, normally a quick burnout will do.
Old Apr 19, 2010 | 05:08 PM
ETW 360's Avatar
ETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant future
18" Mickey Thompsons will do the trick. Are those CCW classics in your avatar? Do you have bigger pictures?
Old Apr 19, 2010 | 08:09 PM
yes they are. Don't have any bigger pics rite now but I'm planning to run the stock hollow spokes at the track
COBB Tuning
Jan 1, 2025 09:02 AM
Jul 29, 2019 11:13 AM
COBB Tuning
Nov 9, 2015 08:02 PM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
turbotuner20v
Sep 11, 2015 12:02 PM
