Lowering ROW suspension - Cosmetics only
Old Jan 16, 2005 | 07:57 AM
RCH's Avatar
RCH
RCH is just really niceRCH is just really niceRCH is just really niceRCH is just really niceRCH is just really nice
Was at Auto salon Singen today and saw a lowered TT, which looked awesome, how can I lower my car 15-20 mm without altering the ride ??
Old Jan 16, 2005 | 10:13 AM
Zippy's Avatar
Get the JIC coilovers. Your ride will be lower & more complient. (Unless you drive over a large bump)
Old Jan 16, 2005 | 10:31 AM
RCH's Avatar
RCH
THKS
looks like Eibach springs might work too ?
Old Jan 16, 2005 | 10:45 AM
cab4kw's Avatar
Junior Member
cab4kw is infamous around these parts
I was in your same situation 6 months ago, considering all the options. ROW is the most reasonable but not adjustable. If you are going to spend the labor in installing it, you should consider PSS9. I purchased mine from AWE tuning and the ride is softer on straights and handles much better than US spec factor suspension. Setting below 4 is softer than factor and setting 1,2, &3 is stiffer. The nice thing about PSS9 is that if you don't like the height, you can adjust it any way you want and realign the car. I don't think the ROW is low enough to be worth while, just my taste
Old Jan 16, 2005 | 12:39 PM
03-turbo911's Avatar
Senior Member
He's already got ROW since he's in Europe.
Richard, a friend of mine tried techArt springs and says that the ride is not that much changed over stock. I guess you're in Switzerland, so you could try Sportec. A full coil-over is much better though and the labor for the instal is the same, so think about that.
Jul 29, 2019 11:13 AM
jc05e46m3
Sep 1, 2015 07:17 PM
mr2by4
Aug 30, 2015 01:50 PM
ECS Tuning - MB
Aug 21, 2015 02:25 PM
Aug 19, 2015 06:35 PM
