Porsche OEM Short Shifter Question
Old Jan 20, 2005 | 07:23 PM
Dock (Atlanta)'s Avatar
Dock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really nice
james - You're right; I don't have any spring echo on any of the gears. I wonder why you feel this on the 1-2 shift??
Old Jan 20, 2005 | 08:02 PM
Ruiner's Avatar
Originally posted by james
I agree with Dock that the feel is diff't. I had the SSK without the linkage for about 6 months and then got the linkage. One thing that is diff't is that there is a feeling I could best describe as a spring echo through the shifter now. It almost has a ping quality to it. Does that make sense to anyone else? Dock, I don't remember that feel on you shifter and it happens to me only on the shift to 2nd. It still feels solid and I like it, but the shift linkage is responsible for this new difference.
That could be the ShiftLink tapping the housing as you shift. I had that before I adjusted the cable lengths.
Old Jan 25, 2005 | 10:42 PM
cporterfield's Avatar
cporterfield is infamous around these parts
I have the Porsche SSK (from Brandywine Porsche) AND the Evo shiftlink. I had previoulsy bought a B&M, but it just seemed like a better idea to replace the whole shift unit and still have the stock unit to put back in if I ever needed it.
The factory SSK works, very, very well. I had the local Dallas tech guru, from Boardwalk Porsche, drive my car. His opinion is that the shifter is now "right" and perfect.
Old Jan 25, 2005 | 11:28 PM
AndyW's Avatar
AndyW is infamous around these parts
Plastic OEM Porsche pieces that fail to stand up to performance shifting
Since we're talking about plastic OEM pieces, I thought I'd share my own experiences of 'failure'. No, not on the shifter, not on the shift link... but the assembly in the attached pictures. Not sure how to describe it... I'll let the pictures tell the story. Let me know if you have questions. But essentially, the front part of the assembly, was missing 'a tooth', but the back part, completely broke into pieces, so that all the 'teeth' of the piece essentially fell-apart.
Thanks,
Andy
Old Jan 26, 2005 | 07:29 AM
Ruiner's Avatar
Andy, those get replaced when you buy the B&M SSK. Of course, the replacement parts are metal and will not break like the plastic housing did on your unit:
Old Jan 26, 2005 | 09:43 AM
collin996tt's Avatar
Senior Member
collin996tt is infamous around these parts
That's the thing the under car SSK won't get rid of, the plastic parts.
Old Jan 26, 2005 | 10:28 PM
AndyW's Avatar
Hmmm.. .that's encouraging, so the two end pieces (oem=white plastic), gets replaced with metal pieces. NOW... I have to ask, what about the whole 'plastic assembly' that these pieces sit in ? Although, it appears more 'sturdy' than the two white end-caps... I wonder if anyone has had experience about "it" breaking. btw.. thanks for the pix!!
Old Jan 26, 2005 | 10:43 PM
MKW's Avatar
MKW
MKW is infamous around these parts
Those OEM plastic bushings/bearings rarely fail - it's the cable end pieces that go - that's what the EVO pieces replace . The in tunnel SSKs don't address that "problem", either.
OTOH, some have stated the OEM cable end pieces ( cheap ) are designed to sacrifice themselves in bad/ hurried shifting so as to spare the tranny ( expensive ). I'm sure Porsche does it that way on purpose for warranty cost containment purposes as the owner would never fess up that he blew a shift while driving aggressively.
Old Jan 27, 2005 | 06:40 AM
NC Bob's Avatar
NC Bob is infamous around these parts
Originally posted by mehrabani1
How much, and where can I get it?
Brandywine has the B&M on sale for $199. Not sure where to get the Evo other than EVO.
Old Jan 27, 2005 | 07:05 AM
Ruiner's Avatar
I haven't personally heard of the centerhousing breaking, but perhaps that is too naive to think. Maybe some others can chime in, but it seems to be a rather solide piece in all respects.
Old Jan 27, 2005 | 11:25 AM
Tool Pants's Avatar
Tool Pants is infamous around these parts
Neat pictures. I have put in a lot of short shifts and never seen a broken tab on the oem bushings. I have never seen any cracks in the black plastic shift tower.
For Andy, show up at the next work on cars days in San Jose and we will help you fix it. http://www.renntech.org/forums/index.php?showforum=41
If you want to keep the oem shift then buy the metal bearings from EVO as already suggested. Porsche does not sell replacement bushings.
You could also buy the entire oem shift tower, or put in a B&M if you like the feel. You can use the B&M bushings with the oem shift, but you have to buy the entire kit to get the bushings.
For other local owners, I would like to see if I can put in the new 997 Porsche short shift in a 996/986.
Old Jan 28, 2005 | 12:48 AM
AndyW's Avatar
Thanks, I'll look for the 'next' (looks like I just missed one) tech day.
I've already fixed my situation with complete OEM stuff... but thinking about re-changing it to something a little 'sturdier'.
Not only was one tooth missing from the front bushing, but ALL the teeth got busted up in the back bushing :-)
Andy
Old Feb 5, 2005 | 12:46 PM
jdl175's Avatar
jdl175 is infamous around these parts
Brandywine Sells EVO!!!!!
The shift link is available at Brandywine as well for $129.95.
joseph_number1
Jul 19, 2018 05:45 PM
TrackOne
Aug 20, 2015 12:56 PM
Vrseis
Aug 20, 2015 07:41 AM
ECS Tuning - VW
Aug 19, 2015 08:58 AM
