Vbox 60-130 tips..
Old 06-22-2010 | 12:32 PM
Vbox 60-130 tips..
just got a Vbox. any tips and suggestions on how to do 60-130s. never done these before.
i have k24 turbos, exhaust, tune, 5bar, 6speed manual.
gear (3-4 or just 4) ? when to start the run?
thx
#TeamAIM
Old 06-22-2010 | 01:01 PM
GT2CS's Avatar
GT2CS is infamous around these parts
Try from about 40-50mph and floor it in third. Repeat with second gear start and then try 4th gear and see what you come up with. Will all depend on when car hits full boost and how good your gearchanges are
Good luck.
Old 06-22-2010 | 01:47 PM
DEEPBLUE's Avatar
DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !
I found that the least shifts, the better, but then again I am fairly mod'd and am near 7000' asl for what it's worth. Aslo be wary of altitude changes for getting the numbers published, what you think is a flat surface (<3% I believe) may not be.
Old 06-22-2010 | 01:50 PM
bbywu's Avatar
What is your fuel shutoff on your ECU tune - this will dictate whether or not you will be able to do a single shift (3-4) run.
Old 06-22-2010 | 02:04 PM
Neil Switzer's Avatar
Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !
+1 on the shifts. You need to be pulling maximum boost before or while you hit 60. If you are just cruising at 59.9mph and stab the throttle your times will be poor.
There is many theories on doing these, I know my bro Tym has a bit of experience and tips, many of which he probably wouldn't let you in on, but that is just the name of the game.
Old 06-22-2010 | 02:22 PM
MBailey's Avatar
For cars with similar mods to the OP, the best method in my experiance is to start at 2K rpm in third, floor it shift as quickly as possible, then ride fourth to the limiter. Depends on tire/wheel and ECU shutoff whether you can hit 130 in fourth. Many tunes raise shutoff to 7K in which you can easily hit 130 in fourth.
Some cars do better just running the whole thing in fourth (ie no shift). Others (mostly high hp cars with big turbos and raised redlines) do better with a two shift approach.
Just experiment some. Its interesting to see whats best for each car. Be sure to tell us how you do...
Old 06-22-2010 | 02:30 PM
BlueFVD-575's Avatar
BlueFVD-575 is a splendid one to beholdBlueFVD-575 is a splendid one to beholdBlueFVD-575 is a splendid one to beholdBlueFVD-575 is a splendid one to beholdBlueFVD-575 is a splendid one to beholdBlueFVD-575 is a splendid one to beholdBlueFVD-575 is a splendid one to beholdBlueFVD-575 is a splendid one to behold
Subscribed....I also have a fresh PBox and cant find enough space to safely get to 130...also dont want to get arrested. I dont think I can make it to 130 in 4th....probably have to wait to get to Mid-Ohio
Old 06-22-2010 | 02:36 PM
ttboost's Avatar
Just got my new Pbox too. Haven't had space to get to 130 yet, but a few 50-70's are logged. To the OP. Start in 3rd at 30-35mph, stomp on it, shift BEFORE redline (quickly) to 4th and stay in 4th until you hit the limiter. This is USUALLY the best method. However you do it, the idea is to be a full power (boost) when you crank past 60mph. Good Luck and keep us posted. If you can't get to 130 try some 0-60, 50-70, 70-90 just to get an idea and learn the software, if you don't know it already.
Old 06-22-2010 | 02:41 PM
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
What's the big deal about offering a few tips to someone how best to run 60-130?
Old 06-22-2010 | 02:45 PM
ttboost's Avatar
Maybe just the top secret brake boosting no one knows about? (that only gives me about a tenth or so)
Old 06-22-2010 | 02:49 PM
ColoradoSilver's Avatar
ColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud of
I use this technique only at speeds over 100 mph
Old 06-22-2010 | 02:51 PM
bbywu's Avatar
I guess the other thing that is obvious...program your VBOX correctly to read a 60-130. You don't want to be staring at your VBOX to make sure that you hit 130 when your eyes should be on the road, lol.
Old 06-22-2010 | 02:58 PM
ttboost's Avatar
Most of the ones I have seen, including MY new one, seem to come pre-programmed for 60-130. I just had to stick my 50-70 in there.
Old 06-22-2010 | 03:15 PM
2muchtime's Avatar
2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute
agreed, hard to find those long - safe enough roads to run, at least everything here in South Florida is flat.
Old 06-22-2010 | 03:19 PM
I know in the higher HP cars such as Sledge can do a 60-130 across about 750 feet, cars such as a stock TT take about twice that distance.
Still haven't found that 2.999% decline road yet either...
Quick Reply: Vbox 60-130 tips..
