What do you guys think of this car (Subaru)?
Neither is Subi. Wrong choice.
A good candidate to traffic light race with kids in stride Mustangs though.
For drag racing, and something that would be along the lines of the STi, why not look into a modded Supra turbo? There a lot of us that have come from that car, and I'm pretty sure you won't find any of us knocking it for anything.
Would do great at the dragstrip, and roll-ons won't be any issue either
Long time lurker and first-time poster chiming in here. I currently own an '08 STI (looking at maybe a 996TT or 996GT3), and if I were in your position, I'd look into something different for a strictly drag-racing platform.
I'm going to have to second what 's14roller' suggested, a nice AUTO MKIV Supra. That motor is probably as 'bulletproof' as the 996TT's motor, and the slushbox can be easily built with a high stall and still handle the power that you want to put down. Plus, even with a big snail, you could give it a shot of nitrous to help it spool off the line. I really think that the 2JZ-GTE powerplant is going to be far superior in terms of reliability than the subie boxer motor at the power levels you're going to be achieving.
I also had a 1997 RSP SC300 with a JDM 2JZ-GTE swap + some mods and a 3,800 RPM stall from Boostlogic, and it was a ton of fun to drive.
Jon
Jon
I have TONS of experience with STi's. Here's a few things:
1. Don't pay that price. I've seen similar cars go for way less.
2. The axles are the weak link. Driveshaftshop.com is your answer.
3. These cars are a money pit. It seems as though some of the highly modded ones are always in the shop.
4. I would like to know who has tuned it.
If it is a reputable tuner and you get a lower price, I'd say go for it if you understand that the car is a money pit and expect things to break from time to time.
Best of luck with your decision. STi's are great cars.
Sean- how fast are you trying to go? I would not go with a subaru for drag racing. Axles break when you start using drag radials and so do the trannies. Not to mention that Even though that particular has ALOT money invested into, it is just too much to pay 45k for a subaru.
Now again it depends what you are looking for but for 30k you can get an 2006 E55 AMG and make go low 11s for $2-3k it will be able to do that on the street and at the track. The car will have 4dr and can be used as multi purpose vehicle, family etc. Those car launch great. I used to cut 1.6x 60' on 255/50/16 Mickey Thompsons. The car is so consistent, that it is virtually unbeatable on the street even when racing more powerful cars.
Not into MBs - look into an 03-04 Terminator. You can pick a nice one up between 15-20k, parts are cheap, power adders are cheap. Starting out with a capable motor is always nice.
Turbo supra is always there too
#TeamAIM
#TeamAIM
Thanks everyone....you are probably saving me a lot of money.
I will probably relay the info I have gotten here and say I will have to pass.
I will also politely say that I could pay $35K if he really wants to let her go (he is set on buying a z06 for 45K) and apologize for lowballing him.
Sean just break down and build one of these and I'll drive it for you when you get scared!
http://www.youtube.com/watch?v=JMifm8FMS_4
Because I know the first time it does this you'll poop your pants!
http://www.youtube.com/watch?v=n7l0gamCNOs
Sean,
Cool car that is really a money pit.
Sell the M3 and get yourself a fast comfortable sedan
(tuned E55 like S-351 just sold, C63 AMG, or something like that),
as you would kind of be "tripling up on cars like my next door neighbor that
has Lexus LX570, Q7, and a Defender 90...)
If you are wanting to stay import and in that price range you could get an Evo that would walk all over that STi.
We build a lot of high horsepower Subaru's through here. Cosworth is top notch. Is it a stock sleeved motor? If not without Pinning the block, or sleeves it will not hold long term going over 26psi. The Subaru's are nice cars to trick out. But I don't suggest them for drag racing if you want to go faster then low 11's.
Good luck with your hunt!
I don't see any sleeves:
Cosworth longblock w/billet crank
Cosworth intake manifold rotated
Hydra 2.6 Ecu
Exedy triple plate clutch
Element GT75 turbo which is like a 35/40R V-band rotated custom uppipe w/v-bands custom downpipe
Element catch can system
Custom fuel system Aeromotive 6 adjustable fuel pressure
regulator,Aeromotive top feed fuel rails w/ Full blown dual pump hanger, Aeromotive Eliminator fuel pump in rear, Bosch Indy 1600cc injectors
Custom GT-Spec header
Tial 44mm wastegate
Tial blow off valve
DSS 1000 whp axles
acpt Carbon fiber drive shaft
Chargespeed type 2 body kit w/diffuser
Have Chargespeed 370 mm carbon wing that is not on right now
Seibon carbon fiber hood
visteon radiator
Tein Flex
suspension
Tein EDFC motor kit
Tein EDFC Controller
Blitz FATT Turbo timer
Turbosmart E-Boost 40 psi 60mm
Defi gauges: EGT 60MM
FUEL PRESSURE 60MM
OIL TEMP 60MM
WATER TEMP 60MM
BOOST 60MM
OIL PRESSURE 60MM
Orange electric tire pressure monitoring system
Cusco aluminum front & rear strut bars
Cobb adjustable sway bars
GT-Spec 3 piece subframe kit
GT-Spec Diff mount
Kartboy endlinks
Kartboy short shifter
DBA 5000 SERIES FRONT ROTORS W/ BLUE HAT
DBA 4000 SERIES REAR ROTORS
Hawk HPS brake pads
Autopower rollbar
Takata harnesses
Carabeu racing seats
SSR Type-F Wheels 18x9.5
Dunlop Dirrezza sport z1 265/35/18
Hydra 2.6 Ecu
regulator,Aeromotive top feed fuel rails w/ Full blown dual pump hanger, Aeromotive Eliminator fuel pump in rear, Bosch Indy 1600cc injectorsCustom GT-Spec header
Tial 44mm wastegate
Tial blow off valve
DSS 1000 whp axles
visteon radiator
Tein Flex
suspensionTein EDFC motor kit
FUEL PRESSURE 60MM
OIL TEMP 60MM
WATER TEMP 60MM
BOOST 60MM
OIL PRESSURE 60MM
GT-Spec Diff mount
Kartboy endlinks
Hawk HPS brake pads
Autopower rollbar
Takata harnesses
here is my E55 taking care of business....at that infamous light against couple guys who know what do with their cars from a dig.
http://www.youtube.com/watch?v=YvnnzdO_34A
http://www.youtube.com/watch?v=xB6gJ7mroqY
#TeamAIM
#TeamAIM
