PSM & ABS failure lights on simultaneously at track>>>
Old Jul 12, 2010 | 02:05 PM
mtesh73's Avatar
mtesh73 is infamous around these parts
both lights came on about midway through a run. the lights remained on. i turned the car off and restarted a few minutes later with no other issues. both lights have remained off for the following 4 runs. any ideas??
Old Jul 12, 2010 | 02:26 PM
GT3 Chuck's Avatar
Administrator
if you had one wheel in the air when applying the brakes that would set off the abs light..shutting down, restarting and driving would re-set the light
Old Jul 12, 2010 | 03:03 PM
DERBOOST's Avatar
DERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of light
Check your MAF. Failure will cause both abs and psm lights...been there myself
Old Jul 12, 2010 | 06:41 PM
Mike01996TT's Avatar
Mike01996TT is infamous around these parts
I had a diverter valve cause the same problem but only when idling. Easy to check though.
Old Jul 12, 2010 | 07:48 PM
mtesh73's Avatar
that could be it>>>>
there is a high speed rise come to think of it, probably 100-115 mph, i think that is when the light came on. hmmmmm????
thanks for the info.....it has been fine since. weird!
Old Jul 12, 2010 | 08:29 PM
FAST FWD's Avatar
FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !
You might want to check to see if there are any codes stored from the event.
It seems that there are at least a dozen faults that produce this pair of lights, from MAF to ABS to brake switches to steering angle sensor to ride height sensors to ... It seems that any fault codes that make the ECU doubt the legitimacy of its inputs will make it shut down the PSM lest it cause more problems by over-riding the driver based on bad data.
Old Jul 13, 2010 | 07:29 AM
drhenrock's Avatar
drhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to behold
Happen to me also changed smoke test neg for leaks, changed MAF still happen once since then and resets it self quickly. Pelican parts was cheapest for the MAF, but i would check for other codes and hold off and see how often it happens and does it reset itself...
DetomasoGTS74
Nov 11, 2015 09:01 AM
carwash
Sep 26, 2015 03:11 PM
henryr
Sep 24, 2015 08:22 PM
hacellular
Aug 31, 2015 08:34 AM
GSR Autosport
Aug 26, 2015 05:20 PM
