Ok, how long will a drum of race gas last if you use some here and there?
Old Jul 19, 2010 | 01:06 PM
UrbanHotrod's Avatar
UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !
Nick just spoke to my VP rep, Ok so your good for 3 years as long as its at a constant temp and no condensation.
Put it on a skid he said and your good.
Old Jul 19, 2010 | 01:10 PM
ttboost's Avatar
Originally Posted by PALETTE
And if you need a hand i can help!
Thanks Corey..I got it...
2muchtime's Avatar
2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute
I had to put mine in a hard plastic 5 gal gas container since the plastic pull out piece on a 5 gal disintegrated.
Old Jul 19, 2010 | 01:23 PM
unvmy996's Avatar
Thanks corey , deffinately no condensation .
Old Jul 19, 2010 | 01:31 PM
then your good!!!
when we going to see some Video or times from that bad boy!
Old Jul 19, 2010 | 02:18 PM
unvmy996's Avatar
Corey , VERY soon , im doing a new race file with todd.
Old Jul 19, 2010 | 04:21 PM
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
Originally Posted by bbywu
Mark brings up a good point. I've been told that race fuel should not be stored on concrete or in plastic containers because nitromethane can leech out. Not sure if this is truth or myth.
- bob
Myth. If gas or solvent leaches out, then it has to do more with the construction/material of the can rather than the surface the can sits on. VP fuels come in a steel can which when stored properly and away from water, will last for years. Plastic containers (even hard polypropylene ones) are not recommended for long term storage of gas as they will slowly deteriorate and gunk up your gas. I do not believe there is any nitromethane in ms109. The stuff does not mix well with gas and when combusted, forms nitric acid, a highly corrosive substance. You would have to thoroughly clean your engine if you added nitromethane or your engine will eventually freeze up.
Old Jul 19, 2010 | 04:33 PM
TTdude's Avatar
Originally Posted by ttboost
Hmmm...yeah, it's no good now...I'll be down this weekend to pick it up and dispose of it properly for you...
LOL . You better watch out for this guy.
Old Jul 19, 2010 | 05:22 PM
Dr_jitsu's Avatar
I have been told that you are good for a year.
Old Jul 19, 2010 | 11:26 PM
unvmy996's Avatar
I had a vp rep call me and Corey and tt dude are correct ,in the drum stored at temp and keeping the bung tight after you open it , it will last for years.
Old Jul 20, 2010 | 12:17 AM
bbywu's Avatar
Did you just say you liked your bung tight? LOL
Old Jul 20, 2010 | 12:47 AM
TTdude's Avatar
I don't think he quite said that but lmfao.
Old Jul 20, 2010 | 01:27 AM
essayons's Avatar
essayons is infamous around these parts
other than storing your POL in a steel drum sitting on the concrete floor, you're fine. Put it on a pallet and there should be no issues. Keeping it off the ground keeps moisture from bulding up underneath/around the bottom edge.
Old Jul 20, 2010 | 07:35 AM
Neil Switzer's Avatar
Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !
Damn Nick, use that fuel already!
I just saw the thread but looks like you guys figured it out so I will join in with Bob and say:
Old Jul 20, 2010 | 09:22 AM
bbywu's Avatar
lol!
