Suck, squish, bang, blow: Engine Basics
Old Jul 29, 2010 | 04:56 PM
Divexxtreme's Avatar
Here you go guys. I figured some of you would enjoy reading this article. It covers the basics of how an engine works. I'll post some follow-on stuff later. Enjoy!
By Mike Kojima http://www.motoiq.com/magazine_articles/articletype/articleview/articleid/1434/suck-squish-bang-blow-part-1.aspx
Have you ever gotten soundly beaten at the strip by a lesser car that you should have smoked? Does your buddy with his almost stock identical car pull away from you in a roll-on consistently even though you supposedly have all the best bolt ons? Tired of losing in front of the crowds at events? Does the local “Guru” who works at your friendly neighborhood speed shop intimidate you with quasi-scientific BS when you try to buy something? How do you know if the mail order house phone salesman is giving you the straight scoop on that camshaft he is recommending? Which of many turbos on the market should you get for your car? If these questions seem familiar, then this series that we are launching is something you should read!
In the coming months we will explain all of the basics of how to extract more power from that noisy chunk of metal connected to the wheels. Your new knowledge can be put to good use when selecting hop up parts for your ride, helping you make good solid choices of where best to spend your hard earned money. With knowledge you will be able to make informed choices when buying parts and will be less likely to get punked by unscrupulous mechanics. In this series we will explain how all the popular hop up parts work, how to understand there specifications and how to pick the right parts to best fit your needs.
To understand how the latest in speed parts work, you first need to understand how an engine works! Let’s get down to it and see what makes a basic automobile engine tick. We will break this down into its most simple basic elements because we need to make sure all of you readers are on the same page. If you are an advanced guy, you might not need to read this but let's not make any assumptions about anyone's abilities. We will be getting into the most advanced concepts of engines soon enough as we all progress in our base of knowledge.
Cars are, for the most part with the exception being the Wankle cycle rotary Mazda, powered by what is called a 4-Stroke engine. A 4-Stroke refers to the 4 strokes in the power cycle, the intake stroke, the compression stroke, the power stroke and the exhaust stroke. We will explain those in a minute. The 4 stroke cycle is how an explosion of gasoline and air can be smoothly transferred into useable power to hurl you down the quarter mile or take you to work. Technically, engine is the correct term to use for a cars power plant because the other common term motor, really applies to electric motors.
An engine also has some major parts, the block, the crank, the rods, the pistons, the head, the valves, the cams, the intake and exhaust systems and the ignition system. These parts work in close harmony in an exacting manner to harness the chemical energy in gasoline, converting many small explosions of air and fuel into a rotary motion to spin your wheels and hurl you down the track.
Lets start with the main parts first:
Block
The block is the main part of the engine that contains the reciprocating components that harnesses the explosive power of gasoline. The block has bores, cylindrical holes that the pistons slide up and down in. The number of bores equates to the number of cylinders. A four cylinder will have 4 bores and 4 pistons, a six cylinder will have 6 bores and six pistons, an eight cylinder will have 8 bores and 8 pistons and so on. The block also contains passages for cooling water and lubricating oil. Blocks are typically made of cast iron or lightweight aluminum.
Pistons are cylinders of aluminum that slide up and down in the bores of the block, the top of the bores being closed off by the cylinder head (we will talk about the head later). To make driving power, a flammable charge of compressed gasoline and air contained within the cylinder is ignited, and the piston is forced down the length of the bore toward the open end of the cylinder, away from the cylinder head with great pressure. This is the basic premise on how an engine works. The piston has rings, which are thin, circular, springy metal seals that fit in grooves around the top of the piston. The rings job is to help seal combustion pressure from blowing past the piston, loosing much of the power producing pressure. The rings also help scrape lubricating oil off of the cylinder walls so it does not get burned up by the combustion going on in the cylinder. If an engine had no rings it would not be able to develop enough working pressure or compression to run. It would burn up all of its lubricating oil in just a few minutes of running as well.
The pistons are attached to a dog bone shaped metal rod. This is called the connecting rod. The connecting rods job is to transfer the force of the explosion shoving the piston down the cylinder bore to the rotating crank. The connecting rod is attached to the piston by a pin known as the wrist pin. This is called the small end of the rod. The other end of the rod is attached to the crank. This is called the big end of the rod as the crank’s journals are much bigger than the wrist pin journals. The crank journals are bigger because the crank journal continually rotates at a high speed as opposed to the simple rocking movement at the wrist pin end of the rod. The high speed rotation requires additional bearing surface area to prevent the rod and crank from being damaged by friction. The big end of the rod spins smoothly on the journal of the crank on a pressurized oil film on a soft metal sleeve bearing. On a typical engine the small end of the rod has a bronze bushing for the wrist pin that is fed by splash lubrication. On some engines the wrist pin is fed from oil scraped by rings from the cylinder walls through a passage from the oil ring groove called a pin oiler. Rarely the pin is fed pressurized oil from the rod bearing from a hold drilled through the rod from the rod's big end.
The crank in an engine is exactly like the crank on a bicycle. It transfers an up and down force, which is the pistons being forced down the bore by the fuel/air explosion, into a rotating motion that can be used to spin the wheels. The crank has off set throws, exactly like your bicycle’s crank except the rods and pistons serve the same function as your legs, when pedaling, by pushing the upward throw down as the piston is pushed down the bore by the explosion of fuel and air. This is what makes your car go! After the piston goes down, the crank rotates and the piston is pushed up the bore again until it reaches the top where it can be pushed down again by another explosion of fuel and air. The crank rotates on its main journals on oil film lubricated sleeve bearings just like on the big end of the rods.
The cylinder head is, on most engines, an aluminum casting that caps off the top of the block and contains the spark plugs, valves and the valve train. The head must contain the explosive force of the igniting fuel air mixture so the explosion of said mixture can only drive the piston down the bore instead of blowing out of the bores top. The cylinder head contains the chambers where the explosion of gasoline and air occurs when the piston is on top of its upward stroke. This is called the combustion chamber. When looking at the underside of the cylinder head, the side that bolts to the block, the combustion chambers are the depressions that line up with the tops of the bores. The cylinder head has the combustion chambers cast into it. The valves and sparkplug are located in the combustion chamber. It is in these chambers where, when the piston is at the top of its stroke, the fuel air mixture is ignited by an electrical arc created by the the spark plug, kicking off the power stroke. The cylinder head also has cooling jackets filled with circulated water to help keep the combustion chambers from getting too hot.
On a modern engine the head also contains the intake and exhaust valves. The intake and exhaust valves are spring loaded poppet type valves. The springs hold the valves shut, but allow them to be opened with a push. The intake valves open to admit the explosive mixture of fuel and air into the combustion chamber. They then close to allow the engine to build up compression pressure as the piston, driven by the crank comes up to TDC or top dead center, this is what engine builders call the event when the piston is at the top of the stroke. When the spark plug ignites the compressed, explosive fuel air mixture, the piston is driven down by the explosion, turning the crank. The exhaust valves open near the bottom of the pistons downward travel, allowing the burnt waste gasses to escape when the piston comes back up the bore as the crank spins to prepare the combustion chambers for the next charge of fresh fuel and air.
The valves are opened and closed by the camshaft or camshafts which are basically rods with off center bumps or lobes on it that spins in the cylinder head at 1/2 of the crankshafts speed. The lobes of the camshaft push the valves open and closed so that air and fuel can be admitted with burnt exhaust being expelled. Sometimes the cam can work directly on the valve. Many motorcycles and racing type engines are like this. Typically the camshaft works the valves through a rocker arm which is like a miniature teeter –totter. One end of the rocker arm rubs on the rotating camshaft with the other end pushing the valves open and closed.
Modern valvetrains (the parts that open and close the valves, including the valves, cams, valve springs and other parts to be discussed) are typically called overhead cam valvetrains. This means that the camshaft is contained within the cylinder head on top of the valves. This is opposed to overhead valve systems common in many domestic V-8’s that have the camshaft located in the middle of the block, connecting to the valves with, lifters, long pushrods and rocker arms. Overhead cam engines are typically better for the typical high rpm, small displacement compact car or motorcycle engine, because they have simpler, lighter, more direct acting valve trains. These valvetrains work better at high rpm because their lower inertial mass allows them to follow the camshaft’s lobes with more accuracy. If the engine has only one camshaft that controls both the intake and exhaust valves though rockers it is called a SOHC or single overhead cam engine. The Honda D16 that is found in the ever popular Civic and the Nissan VG30 are examples of SOHC engines.
Many modern high performance engines have dual overhead cams which means that they are separate cams for the intake and the exhaust valves. The advantage with this is that the cam can be placed very close to the valve allowing the cam’s lobes to either work directly on the valves or through a very small rocker arm. This reduces the inertial mass of the valve train to a minimum, which helps high rpm operation even more. Just about all high performance engines use dual overhead cam valvetrains also known as the DOHC configuration. The Mitsubishi 4B11 found in the EVO X and the Honda K20A are prime examples of DOHC motors.
The intake system consists of the manifold which basically is a series of pipes that connect the throttle body, which is the valve the controls the amount of air that can reach the insides of the engine, to the intake ports of the head. The throttle controls the amount of air the engine can suck in, thus controlling its speed and power. When the throttle is shut, the air is very limited so the engine must idle. When it is wide open, the engine takes in all the air it can so it can produce its maximum level of power. The manifold usually contains the fuel injectors which are electro-mechanical valves controlled by the ECU, or engine control unit, a small computer which is the engines brain. The ECU controls the amount of fuel being injected into the engine by modulating the open and closed time of the injectors. Under cruise or light throttle conditions, the ECU maintains the proper stoichiometric ratio of air and fuel for the emissions controls, mainly the catalytic converter to work efficiently. When the throttle is fully opened, allowing the maximum amount of air possible into the engine, the ECU will command the injectors to stay open longer so they can inject a proportionally greater amount of fuel to create a bigger volume of explosive fuel-air mixture. More fuel –air mixture means a bigger explosion and more power.
To get the fuel air mixture burning, the ignition system ignites the flammable mixture by firing a powerful electrical arc across the electrodes of the spark plug. The engine’s ECU controls the timing of this spark. The spark is fired as the piston has almost risen to Top dead Center (TDC) near the peak of the cylinders highest compression. This is the most efficient time to fire the spark. Usually the timing of the spark advances as the engines RPM increases. This is because at higher RPM there is less time for the combustion event to take place so it must be started sooner in the cycle to maintain proper operation.
The exhaust system is simply the tubing that directs burned exhaust gases away from the motor. The exhaust system consists of the exhaust manifold, the catalytic converter and the exhaust pipe. The manifold collects the exhaust gas from each individual exhaust ports in the cylinder head and collects them into a single pipe. This pipe leads into the catalytic converter where poisonous constituents of the exhaust gas such as Oxides of Nitrogen (NOX), various unburned hydrocarbons (HC) and carbon monoxide are converted to non-toxic CO2 and water vapor. After the catalytic converter, the gases flow into the exhaust pipe where they pass through the muffler which reduces the noise to an acceptable level and out into the atmosphere.
The cooling system circulates a mixture of antifreeze and water throughout the block and head keeping them from getting too hot from the continuous explosions that they are subjected to internally. The water is pumped out of the block to the radiator, which is a heat exchanger located in the very front of the car, to be cooled down and re-circulated back through the engine. A faulty cooling system can wreck a motor very quickly by letting it overheat. Although this sounds very basic, my neighbor almost ruined his motor by driving around for several days with his temperature gauge pegged when his radiator sprung a leak. He really did not know that overheating will surely destroy an engine very quickly. The fact that his Integra still runs pretty well once he fixed the radiator is a strong testament to the bulletproofness of Honda engines.
The lubrication system is a pump which delivers oil to all of the engines bearings located on the crank and the valvetrain. The pistons and rod wristpins usually rely on splash that is created as oil is flung off the rotating crank. One of the quickest ways to ruin an engine is to run it out of oil. My neighbor's older brother almost trashed his Acura Legend’s engine by doing this once. He did not realize that periodically you must check the oil level, and ran the engines oil supply down to nothing. Fortunately he asked me what the oil pressure warning light meant, and we caught the low oil level before any damage was done. Don’t laugh, the only reason that I, a supposed expert, know this stuff is that it was drilled into my head by my engineer father. My neighbor's father owns a restaurant and does not work on his car at all. He doesn’t work on cars and my Dad cannot cook awesome Chinese food.
Old Jul 29, 2010 | 06:32 PM
amw's Avatar
amw
amw is a glorious beacon of lightamw is a glorious beacon of lightamw is a glorious beacon of lightamw is a glorious beacon of lightamw is a glorious beacon of light
Good read.
The visuals from this link are helpful too.
http://www.howstuffworks.com/engine.htm
Old Jul 29, 2010 | 07:43 PM
Dr_jitsu's Avatar
The thread title sounds like a **** movie
Old Jul 29, 2010 | 07:56 PM
cjv's Avatar
cjv
Moderator
Nice for basics on many motors, however misses many points on a boxster motor as the boxster motor has many important differences.
Some examples, we do not use a block ....... we use a case, big difference. A case is split in half and bolts together. A block is a solid core in which the bores are part of the block.
Our engines do have have bores, we utilize liners that fit into the case and seal with an o ring type seal.
We do not utilize the type oiler that is utilized in these motors.
Porsche incorporates what is described as a liner oiler which is located in the case near the crank webbing.
Our cooling system is different in that the case does not have water passages that surround the liners. A block has water passages that surround the bore.
Our oil system is dry sump ..... there is no oil pan. In addition it lubricates more than bearings. It lubricates and cools and it also handles the turbochargers. Our cranks do not "splash" oil. There is no oil pan to splash from. We have liner squirters that not only do this job but also squirt the oil on the liners that lubricate wrist pins and help cool the liners.
Some of this articles information can relate however it would be kinda like using the male body to describe a female human. Both human's but major differences.
Old Jul 29, 2010 | 08:12 PM
SFdreamer's Avatar
SFdreamer is a glorious beacon of lightSFdreamer is a glorious beacon of lightSFdreamer is a glorious beacon of lightSFdreamer is a glorious beacon of lightSFdreamer is a glorious beacon of lightSFdreamer is a glorious beacon of light
Nice stuff. Thanks for the info!
Old Jul 29, 2010 | 08:27 PM
Thanks. That's exactly why it's called "engine basics".
If someone can first understand basics of most automobile engines, than they can better understand and appreciate the differences in a Porsche engine.
Old Jul 30, 2010 | 07:25 AM
fdorn's Avatar
fdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud of
Thanks for posting, Scott
ECS Tuning - VW
Aug 28, 2015 11:10 AM
ECS Tuning - VW
Aug 27, 2015 01:37 PM
ECS Tuning - VW
Aug 27, 2015 08:50 AM
