1st (Ethanol) E85 Porsche 911 Turbo by Prototech & Protomotive
Old Aug 23, 2012 | 10:45 AM
  #61
DEEPBLUE's Avatar
DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !
Interesting thing we learned about the 044 pumps though, when you bench test and reach a certain pressure, each pump has a relief (purge) valve that will dump back into the tank (or the bench on this case). I dont recall what that pressure was, but if my memory serves, it was quite high.
Is anyone using a 044 as a boost pump outside the tank? Would be interested in any experiences (mine are both in tank, just curious to those with an external).
Old Aug 23, 2012 | 11:04 AM
  #62
unvmy996's Avatar
this is great info guys.
Old Aug 23, 2012 | 12:48 PM
  #63
evil 996tt's Avatar
evil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud of
My external 044's(and I know of no other design) do not have a dump or purge valve. They have a "check" valve on them, perhaps your thinking of that?
Old Aug 23, 2012 | 01:22 PM
  #64
JETmn's Avatar
JETmn is infamous around these partsJETmn is infamous around these parts
I run one external also (different application) and it does not put any fuel back in to the tank or onto the ground in that case. Maybe you just caused enough pressure to make an o-ring lose its seal?
Old Aug 24, 2012 | 08:09 AM
  #65
speaking of 044s one of mine took POOP. raplced it last night. keep an eye on them fellas.
#TeamAIM
Old Aug 24, 2012 | 08:27 AM
  #66
DEEPBLUE's Avatar
Interesting, maybe it is the check valve that I am referring to.
Sorry to hear about your 044 failure prodigy, any idea what went bad?
Old Aug 24, 2012 | 08:33 AM
  #67
I am not entirely sure but I will be sure to get a fuel pressure gauge and keep an eye on base pressure. With one pump not working it was down to 40psi when I normally run 43.5psi. We spent all evening messing with it, but its figured out now
#TeamAIM
Old Aug 24, 2012 | 10:47 AM
  #68
hroussard's Avatar
hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !
Porsche 991 Diesel???
Not yet but I tell you.. there will be some serious pressure to start using diesel engines in real sports cars... I will be standing in line with my deposit.
http://autos.yahoo.com/blogs/motoram...200130777.html
Old Aug 24, 2012 | 05:09 PM
  #69
m3ntal's Avatar
Senior Member
m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !
Don't forget a filter was on backwards hardly letting any fuel pass by. I'm sure that put a huge strain on the pump.
Old Aug 25, 2012 | 09:46 AM
  #70
evil 996tt's Avatar
You should consider a pressure sensor and just put a dumby light on the dash when the pressure drops or you lose all pumps it lights up.
Old Aug 25, 2012 | 09:49 AM
  #71
DEEPBLUE's Avatar
Thumbs up
This is a good idea, I would be interested in this as well.
Old Aug 25, 2012 | 10:04 AM
  #72
evil 996tt's Avatar
In road racing, this is very common for oil pressure(or lack of). Normally it is as big of lamp as you can get so, when the pressure drops, you see the light and lift. I do this for knock sensing, oil pressure and fuel pump status.
COBB Tuning
Jan 1, 2025 09:02 AM
2lflat4
Nov 18, 2019 05:05 PM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
