help please....jacking the rear
I have seen this addressed in the archives, but a few things not exactly clear. I'm pretty nervous about doing this right and not hurting the car or myself!
I want to get the rear of the car on stands so I can change the exhaust.
Where exactly do you place the jack in the center of the rear in order to lift and place 2 jack stands at the rear jacking points? I've seen both on the cross member and on the engine itself. Anyone with pics of the jack placement?
Also, anyone have trouble with jackstands that have the "U" shaped top on them? Will this be ok under the jacking point or do I need stands with a flat top? Piece of wood between the car and the stand?
Do you guys just jack the rear, or do you put all four corners on stands for this type of work?
Sorry if beating an old subject, but this is the first time for me with this car and these tools and I respect all your experience and learning!
If you're doing this at home make sure you are on level ground with the car in gear (e-brake irrelevant as the parking brake shoes are in the rear discs) Find a short piece of soft 2x4 and put it on the floor jack plate. You can jack the car up with the floor jack/2x4 at the bottom of the engine case either just fore or aft of the oil drain plug. Make certain it's centered. When it's up high enough place the jack stands (use the ones with the smallest foot print) on the jacking points (just east and west of the rear plastic rocker panels). They are roundish male protrusions that are surrounded by plastic panneling. If there is truly any question as to do you have the correct jack point just stop and get further clarrification but it's pretty streight foreward. When placing the stands move them into position with your hand BELOW the point that will make contact with the chasis as the floor jack at this point is the only thing holding the rear of the car up. (try not to ever put your hands anywhere you wouldn't put your ----. ) Once the stands are in place very slowly turn the floor jack handle counter clockwise (it will have some resistance at first- turn to quickly and it will drop too rapidly.) and it will lower slowly untill the car rests gently on the floor jacks. If the rear jack stands are up high enough there should be no need to raise the front of the car and it's much more stable with the front on the ground. It never hurts to place a third jack stand under the engine case as an emergency back up once the others are set.
Originally posted by ebaker
Is it ok to put the jack on the center of the crossmember that runs just in front of the engine case?
Originally posted by Gunther
How come you guys don't recommend placing the jack stands in the designated jacking locations on both sides of the car?
Originally posted by Scott in H-town
Can someone post a pick of the underside while it's being held up by the jack? I'd like to see exactly where some of you jack it up if not using the jacking points.
He is using the jack points (to support left & right jack stands)........but it's a tad tough to both jack & stand at one point at the same time.....that's why the engine case lift is a good short cut. If you don't have a good (low-rise) jack to do that, you can use the method of jacking right front (at the jacking point) high enough to set jack stand under the right rear........but the the engine shortcut is better/easier (and for low cars, this is often the method shops also use).
