Tire pressure?
On the track I'm running 36 Rear and 31 front (cold). I use the "triangle" guide imprinted in the rubber on the sidewall and adjust pressures at the track to get the "grain" to the point of the triangle. I'm still about a half to a pound too high, but I'm happy with it.
I still get a little slip in the rear on full squat coming out of some corners, and some push going in, but it's colder here (Seattle), I have Kevin's tune (tons of torque on K24s), OEM suspension, P-S02As and the track has about 10+ different surface types/materials.
For street - use factory guidelines of 44/36.
would the recommended pressures be the same for 19" wheels?
#TeamAIM
#TeamAIM
Correction as per TSB Rear is 43psi
Sorry i just felt like being a Smart ***
I use same PSI as 18's
Thank you everyone... I was at the track and realized I forgot my cheat sheet.
I wish I would have read this at the track, I only saw the first post and went off of that. I ended up starting with 28 front and 36 rear cold. It was hot out, it got to 34 front and 42 rear when I got off the track... I thought I was too low compared to the stock recommendation, but felt fine after the first lap.
Thanks again!!
Thanks again!!
Thanks again!!
Thanks again!!
Last time i tracked,i went 28 front 30 rear and felt bad.The rear was too happy.
Jul 29, 2019 11:13 AM
RallyBird
Oct 7, 2015 01:20 PM
horsepowerfarm
Sep 10, 2015 06:09 PM
COBB Tuning
Sep 9, 2015 09:13 PM
