996TT Cab Lowered on KW V3 Coilovers
Old Sep 27, 2010 | 04:46 PM
vividracing's Avatar
No hydros on this machine Just KW V3 too! When you coming by Vivid Racing?
Old Sep 27, 2010 | 05:20 PM
Astacun's Avatar
Astacun is infamous around these parts
Originally Posted by Danyol
Looks like you're in Phoenix, I've just moved here, I have the V3's too.
Car looks great but I'd say you're lucky not to have the aero package. The highways are good but everything else here appears to have been designed for UAVs (urban assault vehicles)! I'm running higher than you but the front front splitter is seeing contact fairly often. The roads in Florida weren't great but I've got to tell you the roads round here are rough, the car is riding a lot harder. Perhaps we can compare settings? here's where I have mine now (copied over from another one of my posts),
"Ride height is about 10mm above GT2 (315/25-19, 235) no rubbing issues, (was) good day to day.
Start by closing the valve and then counting the clicks as i open it
Compression = 3 clicks from close
Rebound = 5 clicks from open (yes very loose rebound to prevent the car from having the bouncing effect )"
My ride height is set right at GT2, but I will have to raise the front a bit so that I don't scrape the soon to be installed new front bumper. Regarding rebound and compression, the car was set per de KW manual to the following:
Front Rebound 9 clicks open
Front Compression 1.25 turns open
Rear Rebound 9 clicks open
Rear Compression 0.75 turns open
The rebound has an adjustment range of 18 clicks, so the car is set mid way. I would like the suspension to feel a little more comfortable, so I am going to be adjusting it a little more. I am curious to hear what settings others are using in the street.
Ed
Old Sep 27, 2010 | 06:20 PM
Danyol's Avatar
Danyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant future
Soon...work is getting in the way of play since I moved here . Any time of the day better for visits (morn/aft)?
Old Sep 27, 2010 | 06:58 PM
9-6 M-F, we are here!
Old Sep 28, 2010 | 09:21 AM
Al Norton's Avatar
Al Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud of
Could you please tell me the F&R ride heights after dropping the car?
Old Oct 2, 2010 | 05:48 PM
168's Avatar
168
168 is infamous around these parts168 is infamous around these parts
We do have 5 sets instock. So PM me for special
Thanks for the great price and service Dan. Looking forward to installing mine!
Old Oct 2, 2010 | 06:55 PM
Tarek307's Avatar
Tarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond repute
Wow alot of PHX people here, great! i'm looking forward to finding an 02-03 996 Coupe and hopefully we all run into eachother and share ideas!
Old Oct 2, 2010 | 07:28 PM
robmd99's Avatar
robmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond repute
Dan
Since you were using JIC on your yellow bee how would you compare those CO to KW???
Robert
Old Oct 2, 2010 | 08:57 PM
coastalb55's Avatar
coastalb55 has a brilliant futurecoastalb55 has a brilliant futurecoastalb55 has a brilliant futurecoastalb55 has a brilliant futurecoastalb55 has a brilliant futurecoastalb55 has a brilliant futurecoastalb55 has a brilliant futurecoastalb55 has a brilliant futurecoastalb55 has a brilliant futurecoastalb55 has a brilliant futurecoastalb55 has a brilliant future
Good luck with that nice painted lip! I too have KW V3's lowered to about your specs and my lip looks pretty chewed up. When I replace it, I don't know if I will go to the trouble of painting it. It drags about everytime I leave my driveway and also at a dip near my house.
Assuming that an alignment was done when the suspension was put on, what specs were used? Particular in the rear. I think the rear camber on my car is pretty aggressive and has trashed the inside edge of my PS2s.
Old Oct 3, 2010 | 09:06 PM
i have kw on my 997tt and they are 100 times better in ride and tuning. i had jic on that car too. real you dont know how good coilovers are till you run KW. btw 4 sets instock.
Old Oct 3, 2010 | 09:11 PM
Blockhed's Avatar
Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !
kw coilovers
Dan
what do the kw coilovers go for just curious?
Adam
Old Oct 3, 2010 | 09:51 PM
dzuperku's Avatar
dzuperku is infamous around these parts
Looks sweet! Unfortunately, I don’t think I could pull this off here in Chicago. I am already getting scratched at stock with all the potholes, alleys and other crazy road conditions.
Old Oct 3, 2010 | 09:52 PM
KW V3 retail at $3795. As of 10/1/10 only authorized an direct dealers can sell KW. We still have 4 sets instock at the old pricing.
Jul 29, 2019 11:13 AM
John@SpeedTech
Sep 4, 2015 07:23 AM
MadWhip
Sep 3, 2015 02:04 PM
pshep138
Sep 1, 2015 09:45 AM
