Check Engine Codes
Old Sep 23, 2010 | 06:11 PM
Hogapalooza's Avatar
Hogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond repute
Check Engine Codes
P0133
P0153
P0420
What are these codes for?
Are they serious? ( will it hurt to drive the car? )
The car runs great! But I did do some exhaust work a few weeks ago.
Old Sep 23, 2010 | 06:16 PM
TURBO ELECTRO's Avatar
TURBO ELECTRO is a jewel in the roughTURBO ELECTRO is a jewel in the roughTURBO ELECTRO is a jewel in the rough
133- 02 sensor CKT slow response (bank1 sensor 1)
153- 02 same (bank2 sensor 1)
420- catalyst efficiency below threshold (bank 1)
Old Sep 23, 2010 | 06:43 PM
Ok, thank you. Will it hurt the car to drive it w/ those codes?
Old Sep 23, 2010 | 07:28 PM
wross996TT's Avatar
Most solid codes are emission related and will not likely hurt the car for short trips. Since you read the codes, did you also clear them?
P0133P0153: Possible fault cause: Oxygen sensor is dynamically inert
P0420: Possible fault cause
♦ Oxygen sensor ahead of and after TWC exchanged
♦ Valve lift fault
♦ Aged oxygen sensor after TWC
♦ TWC faulty
Old Sep 23, 2010 | 11:07 PM
♦ Valve lift fault
♦ TWC faulty
Yes I cleared them. Thanks for the info. I did some exhaust work and I'm sure this is why I have them. I'm interested in seeing how long it takes to get the codes again. Thanks again.
Old Sep 23, 2010 | 11:20 PM
they will come back very very soon...
You need a flash that turns off the post 02s off...
mark
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Sep 23, 2010 | 11:29 PM
mark
Thanks Mark, I figured that. My impression from TK is that it won't hurt the car, also that I needed a tune to get rid of them.
Don't worry, I just did a little mod myself while I'm saving for Proto tune and a real exhaust.
I hope all is going great for you and your shop. You should come to Porschepalooza on Nov 12-14th. Only about 60 miles from Harrison.
tropicatango
Jun 8, 2025 01:00 PM
Mini George
Jul 29, 2019 12:20 PM
Mini George
Jan 18, 2016 09:16 PM
