Vivid's 3 Inch Y Pipe
Old Sep 30, 2010 | 12:22 PM
  #31
vividracing's Avatar
Just making sure Your good.
Old Sep 30, 2010 | 12:24 PM
  #32
unvmy996's Avatar
98 oct is equal to out 93 oct here... boost seems high , what tune do you have ?
you must be running very low timing in order to run 1.5 safely...
i would log your afr's just to see.
Old Sep 30, 2010 | 12:27 PM
  #33
oooo yea if you are running 98ron then you are running 93oct at 1.5 is high. 1.3 is best on that gas.
Old Sep 30, 2010 | 12:59 PM
  #34
RCH's Avatar
RCH
RCH is just really niceRCH is just really niceRCH is just really niceRCH is just really niceRCH is just really nice
I genuinely don't think there is a scaling difference; 98 Octane is 98 Octane and 93 is 93 Octane, 95 is standard in Switzerland but every garage also has 98, just like Shell & BP sell in the UK at many garages the hyper expensive 100 Octane. In the US you just have wimp Gas. I have the EPL Billet 16 tune
Old Sep 30, 2010 | 01:22 PM
  #35
unvmy996's Avatar
Ugh ..yes there is the ratting is tottaly different , its been covered here many of times, but whatever keep doing what your doing so when you blow your motor i can tell you i told you so.
there was a thread not to long ago from a guy that he told his tuner that that he runs 98 oct so the tuner over here state side tuned for our u.s. wimp gas .. and next thing you knew bam.... blown motor ,
Old Sep 30, 2010 | 01:37 PM
  #36
earl3's Avatar
earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !
Originally Posted by vividracing
Calculations have nothing on real world testing such as the Texas Mile, Dyno, 60-130.
exactly why I quoted USP car's trap speed. Again, the highest mph-ing 24/18g car (by far) runs a stock y pipe.
<break>
It baffles me that people talk so much about the importance of flow & how much better x product is at flowing, but then we never see anything on a friggin FLOWbench. Am I unreasonable?
Anyways, sorry for the thread clutter Richard, hope your setup works well but I would check to see if the 98 octane is (R+M)/2 or just 98 RON Edit: dick_997 beat me to it!
Old Sep 30, 2010 | 02:32 PM
  #37
RCH's Avatar
RCH
this is all brilliant we are on a discovery process here
Old Oct 1, 2010 | 11:43 AM
  #38
RCH's Avatar
RCH
Petrol or gasoline is assessed, categorised and sold by an octane rating. Generally, in most areas of the world, the Research Octane Number (RON) is used, but in North America, the Anti-Knock Index (AKI) is used. Conventional 'standard' "Premium Unleaded" petrol in the United Kingdom, Europe and Australia has an octane rating of 95 RON, and in North America it is AKI/RdON/PON 91-93 (RON 96–98). However, higher octane "Super Unleaded" - often formulated with higher quality additives, is usually set at around 98 RON in mainland Europe;
Old Oct 1, 2010 | 11:45 AM
  #39
RCH's Avatar
RCH
So apols re the weak US Gas comment, had to go to the airport this morning (flight to Geneva and back) the Vivid full 3" Y pipe certainly pulls though....
Old Oct 1, 2010 | 11:48 AM
  #40
Thanks!
Old Oct 1, 2010 | 05:53 PM
  #41
kwei's Avatar
kwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud of
Richard, congrats on the new setup, if it looks similar to the pic Dan posted I have to say it looks nice. Question, is labor over there (wherever it is you are from) less expensive than we have here in the states? $50/hour is a good deal from where I am sitting. Please correct me if I am misunderstanding.
Justin
Old Oct 1, 2010 | 06:16 PM
  #42
its got to be 50GBP. $50 is cheap.
Old Oct 1, 2010 | 07:22 PM
  #43
Turbo Fanatic's Avatar
I have John's 2.5" pipe and it's a constant diameter all the way to the TB. Actually it looks to be a bit bigger once they "Y" together.
It's a tight fit in own right. The lower left of the fan actually touches it.
Old Oct 2, 2010 | 11:24 AM
  #44
RCH's Avatar
RCH
I noted today that there even had to enlarge the hole in the metal car body from the intercoolers as that is not quite 3"
Old Oct 2, 2010 | 11:29 AM
  #45
If your talking about the hole that that stock hoses go thru to get connected to the ICs... those are more like 3.5" but yeah... its a close fit and requires custom fitting... as most aftermarket parts..
markski
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
