Installing 997 shifter assembly without alignment tool?
Old Oct 6, 2010 | 04:38 PM
Scottslaw's Avatar
Scottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond repute
Hey guys, I've got a 997 shifter I'm ready to install and I've read through several threads and instructions, but I'm curious if I really need the alignment tool that comes from Porsche. If I mark the cables as recommended in the B&M instructions, will this suffice, or should I do something more to ensure proper alignment of the shifter. Thanks!
Old Oct 6, 2010 | 05:45 PM
raineycd's Avatar
I have installed two with no tool and no problems. I counted the number of rings on the old one and installed the new one the same way.
So go for it!!!
Old Oct 6, 2010 | 05:47 PM
tvurt's Avatar
tvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud of
The tool holds the shifter in neutral. It is super "floppy" without it. You should use the tool to hold the old shifter when you mark the cables, and then again when you install the new shifter.
I have a spare send me a PM if you want it.
Old Oct 6, 2010 | 10:06 PM
Etchhead's Avatar
Etchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond repute
+1 just make the cables and go for it
Old Oct 7, 2010 | 09:24 AM
Scottslaw's Avatar
Thanks for the advice guys. This was an easy job...I finished it last night in about 2 hours (going slow). Just marked the cables and everything went back together perfectly. I love the shifter. Much less effort to shift than the b&M I had in the car, slightly longer throws, but much smoother. My 997 unit is a bit unique as the previous owner had the shift rod cut down 10% and machined to accept the stock ****, for a little extra throw reduction. I love it. Thanks again.
Senatorblutarsky
Aug 28, 2015 12:44 PM
oddjob142
Aug 24, 2015 05:49 PM
ECS Tuning - VW
Aug 20, 2015 03:07 PM
ECS Tuning - VW
Aug 19, 2015 08:58 AM
