Dealer Response to 2nd Gear Pop Out
The car was dropped off yesterday. The dealer is going to get authorization from PCNA each step of the way so that I am not stuck with massive labor charges to investigate the pop out in case we find that the PO damaged the 2nd gear. The service rep didn't think that would be the case and seemed very familiar wtih this process. Either way, the dealer agreed to take advantage of the "free" labor and install a new clutch package and will match Suncoasts' price quote. Nice. They also believe that they will get authorization to replace the painted crest center caps.
Never mind that it happens once or twice a month and clearly would have been missed in the 20-30 minutes they drove the car.
My experience from across the pond.
I had my 2nd gear pop out done on what is called the 'Porsche Approved' warranty here in the UK. I too was warned that if there was signs of 'abuse' then the claim would likely be rejected. I was confident that it wasn't abuse as the symptoms were text book.
After it was opened up there was no question it was anything other than the well documented problem and they fixed it. All the while I had a RS60 to run about in and they had the car for about two weeks.
Gearbox felt so much better (and still does) when I got it back. They must have renewed quite a few components.
The 'charge for warranty investigation' isn't a Porsche feature. I've seen it on most brands that I dealt with. If they find a warranty issue, as you said before, it's fully covered. But if it isn't, you're on the hook.
Sucks, especially if you're in a situation where you have to believe everything they tell you, but it's pretty standard...
You should ask this:
"If I agree to 1200, will that be the SOLE charge if PCNA declines the repair and I decline the repair?"
At a dealer, it seems $1200 gets the case open...and NOT put back together!
A
PS Have you downloaded and read the TSB they will use to determine fault?
I'm sorry but this is the script for this story every time it is posted...
A
A
Same old script indeed. Yep, they had the TSB which I read. But with zero track time, pristine condition, 28k on the clock, and a clean ECU download, the dealer is pretty confident that this will be a straight forward warranty repair. PCNA said even if it isn't, they are willing to cover a repair under a good faith warranty repair...not sure what that might mean, but I seem to be in a good place at this point. We'll see how it goes.
Bigger issue with the tranny is that they look at the parts and determine what caused the problem based on the internal damage....
An abused gearbox normally means poor shifting quality as the syncros take the brunt of the abuse.
Here is a link to a supplier on your side of the pond. Perhaps you could call them if you want some reassurance as to what is the normal symptom.
http://www.rsmotorwerks.com/casestudies.php
UPDATE: Synchros are no good. 1-2nd gear are worn. No sign of abuse so PCNA is now deciding whether to rebuild the trans or provide a new one...under warranty. And that is good, the rebuild quoted at $7,300 and the trans at $12,000 installed. My bet is they will chose to rebuild it. Then again, with 16 months left on the CPO, they may just pull the trigger on a new unit. That would be really nice.
