EVOMS Stage I Kit Upgrade
Old Nov 2, 2010 | 06:15 AM
corkemeister's Avatar
corkemeister is infamous around these parts
Installed the Stage I kit from EVOMS this weekend. With help from my son total install took about 5 hours (most of that being the plug change) Relatively easy install but what great results. This is a daily driver and wont be tracked, and is stock, but the EVOMS kit has totally improved the driving experience. Pick up from about 2500 rpm is amazing. So smooth and effortless. Has made an already nice ride absolutely fantastic. Excellent value for money.
Old Nov 2, 2010 | 06:18 AM
Hogapalooza's Avatar
Hogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond repute
Congrats! What comes in a stage 1 kit? What is the est HP/TQ gains?
Old Nov 2, 2010 | 06:31 AM
EVOMS Stage I kit details
Kit Includes:
-EVOMSit Hitachi MAF ECU Tune with SP and IST
-CNC Machined 89mm Billet aluminum MAF Housing - Machined for The Hitachi MAF
-New OEM Hitachi MAF Sensor
-OEM Hitachi "plug and play" MAF Conversion Wire Harness
-Injection Molded 155mm Venturi
-Rotational - Molded Plastic Air Box
-155mm "Synthamax" 100% synthetic fiber, reusable, oil less Air Filter
-Installation Mounting Hardware & Special Installation Tool Included
-Denso Spark Plugs
EVOMS Hitachi V-Flow Air Induction System Features:
-Increases Power and Torque
-Improves turbo boost response
-Installs in the factory location - No modifications required
-Utilizes the OEM “ram air” fresh air duct for lower air intake temperatures and added power
-Airbox surrounding the air filter seals against the OEM decklid to avoid ingestion of hot engine air
-OEM quality, fit and function
Stock Horsepower: 415
Stock Torque: 415
Stage 1 Hitachi Horsepower: 500-510
Stage 1 Hitachi Torque: 520-530
Old Nov 2, 2010 | 06:52 AM
9Eleven's Avatar
9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute
85 to 95 horsepower and a 105 to 115 torque gain with just a flash and the V-flow?
Old Nov 2, 2010 | 07:17 AM
NOLA911's Avatar
NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !
The k16s pick up a decent amount of HP with a flash.. I can't say it will be 90hp though, the intake, plugs, and MAF will do little to nothing for a k16 car.
Your exhaust is your your weakest link now- upgrade and let her breathe!
Old Nov 2, 2010 | 07:32 AM
EVOMS Stage I upgrade
Hah. You must have been talking to my son as that is what he says. Thanks for the suggestion. May be in future plans but very happy with results without exhaust for time being
Old Nov 2, 2010 | 07:45 AM
So you get - maf, plugs, air filter, and tune. That is a lot of stuff to get started. The exhaust is as important if not more then all that but you will get around to it.
You've started down a slippery slope, HP is more addicting the crack!
Old Nov 2, 2010 | 07:55 AM
Agreed. What has surprised me though is the way the power comes on now. Smoother than stock and clearly a lot more responsive. Nice work EVOMS
Old Nov 2, 2010 | 04:40 PM
AeroNsx's Avatar
AeroNsx is infamous around these parts
I wonder what the most power you can get out of the stock K16s is?
Seems like you could get over 100HP increase using the stock turbos. That sounds like a good way to start. Perhaps an exhaust and some better intercoolers would be a nice way to be prepared to step up to some bigger turbos down the road.
I am also very interested in the EVOMs stage one kit.
Old Nov 2, 2010 | 05:15 PM
dixie's Avatar
dixie is a name known to alldixie is a name known to alldixie is a name known to alldixie is a name known to alldixie is a name known to alldixie is a name known to all
I don't understand why they change the oem maf with a Hitache maf for a stage 1 ?
Old Nov 2, 2010 | 06:10 PM
seth_horwitz's Avatar
seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !
It seems like that kit has a lot of parts that will come in handy if you plan to keep going farther with power mods, but overkill at current levels. For that MSRP, you can get a budget exhaust and flash from board sponsors, and have both faster spool-up and higher total power.
Old Nov 2, 2010 | 09:07 PM
ard's Avatar
ard
Flash and exhaust are the items of value...
Actually, it just came to me..
The stage 1 with the maf REQUIRES the person to stick with EVOMS in the future! No matter what else you do, you've got to buy all you items with the EVOMSIT programming...so it ties the owner to EVOMS for all future SW upgrades....and really ALL hardware mods.
Sure a few may mix and match, but most consumers will jsut take the EVOMS path.
Not saying that is wrong (necessarily) but might be why evoms wants that in their stage 1...
A
Old Nov 2, 2010 | 09:12 PM
NOLA911's Avatar
Marketing... it sounds better and more improved than "Flash only"
Old Nov 3, 2010 | 11:52 AM
Lennon31987's Avatar
Lennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond repute
+1, glad you like it tho
Old Nov 3, 2010 | 12:01 PM
Ms4cd's Avatar
Ms4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond repute
So to conclude: This kit "hp gains" are equal to Proto or EPL flash with exhaust but, lots lots more expensive ;(
