Engine cutting off when cold
Old Nov 16, 2010 | 03:59 PM
theincubus's Avatar
theincubus is infamous around these parts
I seemed to be having some problems with my 2004 996 turbo convertible when cold the engine tries to cut off as i brake. It’s not necessarily hard braking even moderate braking drops the RPM and then the engine kicks back again. It seems to go away after 20 minutes of driving.
I check with the specialists and they can’t find anything wrong with it. They’ve suggested that i clean the throttle body and the oxygen sensor. This was done in the last service and it went away for a while and then it just came back again. The same thing happens with and without the A/c
I’m thinking it’s a vacuum leak but why does it go away after a while?
This started recently after I had the diverter valve changed as due to a leak the turbo was unable to kick in. Could it have been something they did then?
Incubus
Old Nov 16, 2010 | 05:11 PM
raineycd's Avatar
Probably need to leak test the system. I suspect they left a hose off or something else is leaking.
Old Nov 16, 2010 | 05:44 PM
dwdwdwwd's Avatar
dwdwdwwd is infamous around these parts
I had exact same problem.
I've been on a track this saturday (small track, revving high in second most of the track for 7 hours - 6 laps at a time). No sign of the problem since then. I have no idea what happened and it's really interesting.
I used same fuel on track as I do daily.
Old Nov 16, 2010 | 10:02 PM
Saint Ari's Avatar
Saint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud of
Some say its the fuel pimp ... split fuel lines .... I have the same issues ... a rarity on my end though.
Old Nov 16, 2010 | 10:03 PM
Saint Ari's Avatar
oh, I meant fuel PUMP LOL
Old Nov 17, 2010 | 08:08 AM
ard's Avatar
ard
Originally Posted by theincubus;3041813
[COLOR=#333333
I’m thinking it’s a vacuum leak but why does it go away after a while?[/COLOR]
Becuase when the engine is warm the DME is running in a different 'mode'...and isn't susceptible to the vacuum leak...when cold it is enough to cause the issue... ?
A
Jul 29, 2019 11:13 AM
Jun 10, 2017 07:45 PM
nlakind
Nov 6, 2015 10:15 AM
ECS Tuning - VW
Aug 19, 2015 08:58 AM
