What are the good and bad of going to a18x 12" rear wheel over an 11"?
Old Apr 21, 2011 | 06:57 AM
  #31
ant_8u's Avatar
ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !
Thumbs up!
Old Apr 21, 2011 | 07:41 AM
  #32
DNugget991GT3's Avatar
still dont get it
i need pictures
on a side note .. am i the only one that gets excited like a school girl when it comes to talking about tires/suspension/brakes ?
Old Apr 21, 2011 | 09:16 AM
  #33
Steve Jarvis's Avatar
Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !
Maybe this will help.
Old Apr 21, 2011 | 09:25 AM
  #34
ok now i get it.
so with that same logic, a 305 30 19 would have more contact patch than a 295 30 18 right ?
Old Apr 21, 2011 | 09:27 AM
  #35
Assuming the car weighs the same and your running the same air pressure, the area doesn't increase, only the shape changes. The wider tire will give you a wider but shorter contact patch shape resulting in more cornering traction. There will be no gain in straight line traction.
Later, Steve
Old Apr 21, 2011 | 09:41 AM
  #36
ok now i think i get it (again)
as long as the weight dynamics of the car stays the same, the contact patch size will stay the same ?
Old Apr 21, 2011 | 09:58 AM
  #37
ant_8u's Avatar
Yes indeedy
The footprint is the same size - but it's a different shape
The shape of the footprint has an impact on the grip levels that are possible
I'll try and write something a little more in depth, but easy to follow, over the next day or two - assuming SJ doesn't beat me to it
Steve, if I write something up can I use your picture?
Old Apr 21, 2011 | 10:53 AM
  #38
ok now my mind is working at 100mph.
is the reason why formula 1 cars handle so great ebcause of teh downforce adding a crazy amount of "load" on the tires that far surpas the actual weight of an f1 car, thus giving it more contact area, thus giving it more grip, thus proving, for a minute that i might be too smart for my own good ?
Old Apr 21, 2011 | 11:22 AM
  #39
landjet's Avatar
Wow, I would have never believed this without the pictures. You learn something everyday. Thanks.
Old Apr 21, 2011 | 11:25 AM
  #40
Nikolas's Avatar
Nikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant future
Downforce adds weight, increasing the contact patch. Decreasing tire pressure also increases the contact patch. Tire sidewall stiffness also has an impact. A softer sidewall and lower pressure can increase the contact patch, but can also impact handling negatively.
Old Apr 21, 2011 | 12:43 PM
  #41
ant_8u,
Feel free to use the picture.
Steve,
Now you have it. It's also the reason we use driving techniques to control traction with weight tranfer.
Trail braking - Load the front tires, unload the rear tires for better rotation and entry into a turn
Lift throttle - Again to tranfer weight onto the front tires and off the rear tires for better rotation typically for mid corner corrections
etc. etc.
FYI we are grossly understating the complexity and real world application of this theory. The more you learn the more you begin to understand how little you know.
Bottom line is with in reason the tire compound will have a bigger impact on traction than the tire size. A 315 is not going to give you noticably more straight line traction than a 295 in the same compound. Wider is typically better (it doesn't hurt straight line traction, but helps cornering traction). This is all within reason of course as taller tire will affect gearing, bigger tires can be heavier and wider front tires can increase steering weight and frontal area.
BTW I don't have a 911 turbo yet, but I do run 19x11.5" rear wheels with 315/25R19's on the rear of my Supra (19x10" with 275/30R19's on the front).
Later, Steve
Old Apr 21, 2011 | 02:10 PM
  #42
ant_8u's Avatar
^ Indeed
My mind was blown the first time I started exploring this subject
I realised there is so much I don't (and will never fully) know
Old Apr 21, 2011 | 02:40 PM
  #43
sunir's Avatar
This is interesting...this is why drag racers use very soft tires with soft sidewalls and much lower air pressures...in fact on a good drag racing launch the drag tires actually wrinkle their sidewalls as the contact patch is optimized to deliver torque to the rear wheels and get a good bite on the launch.
Old Apr 21, 2011 | 02:51 PM
  #44
You will also notice the tires grow significantly to make a tall tire with a long contact patch. This is exactly what's needed for straight line traction.
Old Apr 21, 2011 | 02:57 PM
  #45
sunir's Avatar
very true almost like they shrink in width and become very very tall just for a fraction of a second at launch...this can be seen very well during a drag racers burnout...
good info on this thread!
