Where to get replacement bolt for 15mm spacer
Old Dec 10, 2010 | 05:23 PM
bad107's Avatar
bad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond repute
I recently bought a set of rims/tires with these 15mm spacers...
http://www.fvd.de/us/en/Porsche-0/-/...ith-Bolts.html
However, it was missing one bolt. Any idea of an easy place to get a replacement bolt to work with the 15mm spacers?
Thank you!
Old Dec 10, 2010 | 05:32 PM
tvr-4's Avatar
tvr-4 has a reputation beyond reputetvr-4 has a reputation beyond reputetvr-4 has a reputation beyond reputetvr-4 has a reputation beyond reputetvr-4 has a reputation beyond reputetvr-4 has a reputation beyond reputetvr-4 has a reputation beyond reputetvr-4 has a reputation beyond reputetvr-4 has a reputation beyond reputetvr-4 has a reputation beyond reputetvr-4 has a reputation beyond repute
Thank you!
Have you called FVD?
Next, call Tirerack, I got mine from them.
Old Dec 10, 2010 | 05:34 PM
bad107's Avatar
I can never get someone from FVD on the phone...I will call try tirerack...thanks!
Old Dec 10, 2010 | 08:27 PM
Turbo Fanatic's Avatar
Automotion.com they sel H&R bolts
http://www.automotion.com/catalogsea...=29158&q=H%26R
45mm stock
52mm = 7 mm spacer
60 mm = 15 mm spacer (these will work on 7mm as well)
68mm = 21 mm spacer
Old Dec 10, 2010 | 11:33 PM
MY996TT's Avatar
MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !
I got mine from Vivid, Dan.
Old Dec 11, 2010 | 04:32 PM
bad107's Avatar
45mm stock
52mm = 7 mm spacer
68mm = 21 mm spacer
Thanks!
Jun 10, 2017 07:45 PM
Lucid Moment
Aug 20, 2015 02:22 PM
cab83_750
Aug 19, 2015 12:37 PM
PelicanParts.com
Aug 18, 2015 03:51 PM
