see anything wrong in this data log file?
Old Dec 12, 2010 | 11:00 PM
acuteperformance's Avatar
acuteperformance is infamous around these parts
6 - Denso Iridium plug
Stock Number: 5310
Part Number: IK22
Originally Posted by raineycd
What plugs?
Don't need MAF or the O25 volt...
raineycd's Avatar
And you may add the Lambda for Bank 2 as well just to be sure bank 1 and 2 are close in sync.
Old Dec 12, 2010 | 11:01 PM
raineycd's Avatar
Stock Number: 5310
Part Number: IK22
Oh crap. I wrote a thread on those plugs (well the IK20, but same except the IK22 are colder).
Please, please tell us you gapped them closer than what they came out of the box! They are not gapped proper for a turbo car.
Old Dec 12, 2010 | 11:09 PM
gap too big or too small?
Old Dec 12, 2010 | 11:12 PM
raineycd's Avatar
They come out of the box too big (wide) and will misfire at high RPM and lots of boost. If you haven't noticed a stutter at WOT yet, when you get your boost problem figured out, you probably will have some misfires...
I do not know why they say that part is for our cars, when it is not even close to the proper gap.
Old Dec 12, 2010 | 11:17 PM
Are you saying that once I get my boost leak figured out, if I have stutter at WOT it's because the plugs might be gapped too wide?
Old Dec 12, 2010 | 11:20 PM
raineycd's Avatar
Yep. Hope you don't but I did and so did some others and I burned my plugs up very quickly. It is an easy fix to re-gap them, but the not so easy part is getting to the plugs...
How about your diverter valves? Are they stock or upgraded? If they are stock may want to look at some upgraded or the new Bosch replacements. That will help hold the greater boost more consistent.
Old Dec 12, 2010 | 11:21 PM
They are Agency Power DVs but since that's the easiest and most likely place, I'm going to check there first.
From the logs you can't tell if there is stutter?
Old Dec 12, 2010 | 11:24 PM
raineycd's Avatar
Can't tell from the logs. There may be a misfire on the banks you can tick in durametric to log any of those. If you get a bunch a light on your dash will blink (but mine only blinked in severe misfires).
I didn't notice any misfires until my boost was around 1 bar. Basically, the high boost blows out the spark with too wide of a gap.
Your DVs should be good then. Def do a boost leak check. Lots of places a hose can be loose etc.
Old Dec 12, 2010 | 11:27 PM
Good times. The love hate relationship of turbo'd cars.
Old Dec 12, 2010 | 11:29 PM
raineycd's Avatar
Yep, but it will pay off big! Let us know what you find out!
Old Dec 13, 2010 | 12:08 AM
Neil Switzer's Avatar
Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !
Looks like you are approaching gimbal lock, flux is off the charts...
Old Dec 13, 2010 | 12:10 AM
don't understand..
michael
acute performance
Old Dec 13, 2010 | 12:14 AM
It was a joke Michael, run that thing up to 6800 and let's see the logs.
Old Dec 13, 2010 | 12:16 AM
lol. i was like drrr?? check post #8 has the latest logs
https://www.6speedonline.com/forums/...ml#post3065246
michael
acute performance
