The Red Group - New Suspension Race Package
This is my latest packaged product for my 996 Turbo and Carrera customers. I continually try to release new and affordable products for the Porsche crowd. We have not released this yet, but on the new Agency Power website, all products will come with a LIFETIME warranty. Wear out a bushing, we will replace it!
Track junkies, let me know who wants to get the first Red Group kit for a sponsored deal.
The Agency Power Racing Suspension Package includes all the upgraded products you need to take your Porsche 996 Turbo to the next level in handling. At this point, your car should already have some type of Coilovers and Sway Bars installed. These components will be added to your current setup to improve handling functions geared toward the track enthusiast. Known as "The Red Group", the combination of these parts has been tested and used on hundreds of cars worldwide. The components included in this kit will give your car a more responsive feel by changing out most of the rubber bushings to solid spherical rod ends or monoballs. These parts are designed to work on all Porsche 996 Turbo and Carrera cars from 99-05.
Starting from the front of the car, we begin with changing out the front control arm bushings, also known as Thrust Arm Bushings. These non adjustable bushings press in place of the rubber ones on either the stock or aftermarket GT2/GT3 control arms. They are designed to get rid of unwanted castor that occurs during hard braking or acceleration. Next we upgrade the front sway bar links with a set of our relocated and adjustable links. Many aftermarket coilovers retain the ball joint and rod sway bar link that is long and connects to a bracket off of the coilover. These are prone to breaking and with some sway bars, cannot allow the proper use of the adjustment holes. These aftermarket links relocate to use the wheel carrier pinch bolt as the main mounting position. This gives the link a short distance to the sway bar to eliminate any additional torsion that could break a factory link. The adjustability allows for full range of adjustable sway bar positions and for those getting a complete corner balance and weight alignment, the adjustable 3 piece teflon rod ends allow this to be dialed in.
Moving to the rear of the car, we focus on 3 main components to keep your tires biting and handling precise. The rear sway bar links are much like the front with flimsy rods and breakable ball joints. We upgrade the rear with our solid rear links that use monoballs to reduce any flex in the rear sway bar positions. Moving forward, we change out the rear toe arms with a double adjustable arm to allow further handling settings in achieving the grip your car requires. The toe arms are a complete replacement utilizing heavy duty 3pc spherical rod ends and a precision machined wheel carrier bolt for a direct fit. The final and most popular component to our rear end is the rear adjustable control arms. These arms replace the factory 1 piece "dog bones" that utilize rubber bushings. The Agency Power control arms replace both upper arms to give you a larger range of adjustment in camber and toe. These arms allow easy changes while at the track with their reverse threads and flat turnbuckle. The rear arms are also commonly used for lowered cars that cannot get enough positive camber on the street to reduce tire wear or race cars that need more camber for better handling on the track.
All of the Agency Power products are CNC machined 6061 aluminum and feature steel spacer inserts where necessary. To set it apart from buying individual components in the standard blue color, The Red Group is only available in anodized red as a complete kit. Parts have then been laser engraved with the Agency Power logo or name. All Agency Power parts now include a lifetime warranty. See Agency Power's website for details.
Product is here - http://www.vividracing.com/catalog/a...-p-116689.html
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
PelicanParts.com
Aug 18, 2015 03:51 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 18, 2015 03:42 PM
