removing front differential under tray
Old Dec 23, 2010 | 11:17 PM
xcusemi's Avatar
xcusemi is infamous around these parts
I just finish flush and fill the transmission fluid. I was about to flush and fill the front differential.
I got into a small problem. I went underneath the car and unscrew the 4 10MM plastic bolts and could not remove the front differential under tray. I did noticed seeing the 5 Rectangle Metal Clips that holding the under tray to the car. After trying to ply them out, I could not do it. I would like to know how to remove these 5 rectangle metal clips?
Appreciate any suggestions.
Thank you and have a happy holiday!
Old Dec 24, 2010 | 12:31 AM
porka's Avatar
porka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant future
if you look to the edges of the clips you will see how there is a little clip. use some really small plyers and hook the edge of the clip.. pull it inwards and they should come loose.
i just did mine
Old Dec 24, 2010 | 08:06 AM
FAST FWD's Avatar
FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !
+1 to Porka. I usually slide a screwdriver under the clip and pry it out. I have broken the tab off of one once. If that happens, just order another. It will hold ok with one missing if necessary.
Old Dec 24, 2010 | 11:04 AM
porka's Avatar
just so you know porsche does not even have a service interval for changing diff fluid ever. my car was at 46k and i decided that it couldnt do any harm to swith it out.
therefore its not a necessity, but its an added step you can take to protect your car.
mike
COBB Tuning
Jan 1, 2025 09:02 AM
Jul 29, 2019 11:13 AM
Enemy
Nov 10, 2015 08:01 AM
gulf gt
Aug 27, 2015 10:27 AM
The Oss
Aug 24, 2015 08:19 PM
