Ideas on why car won't start
Old Dec 28, 2010 | 11:06 AM
smithk3933's Avatar
smithk3933 has a spectacular aura aboutsmithk3933 has a spectacular aura about
Yesterday car wouldn't turn over but a couple of times and then click, click; like a weak battery. Put it on the charger a couple of minutes and it started right up. Left it running for 30 minutes and it restarted OK.
This morning, same thing again. I took it to car parts store and had them check the battery. Reading 800 cold cranking amps. The battery was only about a year old.
Seems like the battery is good but not sure why it's not starting. It's been cold but nothing unusual.
Ideas.
Keith
Old Dec 28, 2010 | 11:46 AM
teflon_jones's Avatar
teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !
Bad ignition switch maybe?
Old Dec 28, 2010 | 11:54 AM
smithk3933's Avatar
Would it turn over at all if the ignition switch was bad? And why would hooking up a charger make any difference?
Old Dec 28, 2010 | 11:55 AM
996PCarGo's Avatar
996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold
Arrow Order of things...
1) The battery
2) Ignition switch
3) Starter and/or solenoid
If its your ignition switch the A/C will not engage.
___________________________
Mint “used” (600 mi.) BBS wheels:
18" BBS RS-GTs (600 miles from new)
New Green performance air filter 996:
Green perfomance air filter for 996
New Schnell inhaler kit 996/997:
NIB Schnell Cold Air Inhaler w/caps
Mint “used” (600 mi.) Schnell inhaler kit 996/997:
Schnell Cold Air Inhaler w/caps & instructions
Old Dec 28, 2010 | 12:10 PM
smithk3933's Avatar
1. Battery: Assume the fact that it's got 800 cold cranking amps it is fine.
2. Ignition Switch: Why would it start with charger after a couple of minutes? When you say A/c won't engage, are you talking once the car is started?
Keith
Old Dec 28, 2010 | 12:43 PM
raineycd's Avatar
Lock the car when you leave it if you don't already. Unlocked = serious battery drain.
Old Dec 28, 2010 | 01:04 PM
smithk3933's Avatar
Unlocked drains the battery??? Never heard that, what's the main cause of drain?
Old Dec 28, 2010 | 01:10 PM
raineycd's Avatar
I'm not sure what the drain is, but just have heard that as a common issue with dead battery...
Even locked, mine will die in two weeks... That's on a new battery and alternator...
Old Dec 28, 2010 | 01:18 PM
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
I assume all connections are clean and securely tightened? Even what appears to be a firm connection may not be firm enough for good electrical conductance. Turn your lights on and off and measure voltage. Is it possible to test your battery under load, i.e. use a voltmeter while someone is cranking it over? The battery shouldn't dip below 12.4v or so.
Old Dec 28, 2010 | 01:40 PM
What happens if you put it on the charger for a minute and restart it, but shut it off right away, then try and start it? Does the same thing happen, or can you start it right back up? That would point to the ignition switch. The charger making it work may just be a red herring.
If you can't start it right back up, then I'd figure battery or alternator. I had a similar weird problem a few months ago and it turned out the alternator was on its last legs. It blew a couple of months after the weird behavior started happening.
PorscheEnthusiast
Nov 13, 2015 02:23 PM
vr6tee
Aug 29, 2015 03:52 AM
Senatorblutarsky
Aug 28, 2015 12:44 PM
DSCOFF
Aug 23, 2015 01:22 PM
Rumrunner
Charity Notices/Events
Aug 20, 2015 11:07 AM
