Volumetric Efficiency Comparo
Old Jan 1, 2011 | 03:47 PM
ttboost's Avatar
Thank you for the data!!! There doesn't seem to be a lot of 20g's out there to get data from?
Old Jan 1, 2011 | 06:49 PM
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
Originally Posted by TTdude
Well, I tried to upload the spreadsheet but evidently Excel is not a file type that is acceptable for uploading. So if you want me to send you the spreadsheet just email me at ttdude997@gmail.com.
All one has to do is to input RPM, MAF, and IAT from your datalog. It does not necessarily have to be from Durametric although the spreadsheet is designed to use metric units which Durametric records. Use the plotting function in Excel to generate your graph. This calculation assumes air density at sea level and 3.6L engine. A little tweaking of the density parameter would be necessary if you're running in the mountains or displacement for stroked engine. Peak VE would correspond to peak torque. This is like a "poor man's" dyno. Have fun.
I set up this gmail account so I can distribute the VE spreadsheet but when I went to log in I get a message that says, unusual account activity, please submit your cell phone number so we can send you a message with a verification number--lol. No way that is happening. Last thing I need is gmail spam on my cell phone. So please send me a PM with your email address and I will distribute that way.
Old Jan 1, 2011 | 10:31 PM
TTdude's Avatar
Originally Posted by 996ttalot
TTDude - just sent you my file for my set up which would be good to graph on your original graph.
Here you go! You've got some great flow going.
Old Jan 2, 2011 | 12:07 PM
TTdude's Avatar
X50 vs K2420g
X50 data from 996ttalot. The X50 graphs are truncated because of gear changes which otherwise looks like an etch-a-sketch by connecting all the dots. Thanks Ken for sharing!
Old Jan 2, 2011 | 06:34 PM
FAST FWD's Avatar
FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !
Thanks a lot for posting this. I reduced Bobby's formulas to make it convenient to plot from Durametric data. This uses the data as reported by Durametric (MAF in kg/hr, T in deg C):
VE = 2.63*(MAF)(T+273)/RPM
My results seem to be about 11-12% higher than the reported engine load. I've posted data from my car, which has UMW Stage 2A (K16/997 GT2 zero-clearance)
Jon
Old Jan 2, 2011 | 07:57 PM
TTdude's Avatar
Jon
Nice job simplifying Jon! Interestingly with my 997t, the calculated VEs range between 0-5% lower than recorded engine load values with higher discrepancy occuring at higher load, i.e. VE=44, load=46; VE=226, load 240. Perhaps the 997.1t DME does a better job of calc engine load? Dave
Old Jan 3, 2011 | 02:22 PM
996ttalot's Avatar
996ttalot has a reputation beyond repute996ttalot has a reputation beyond repute996ttalot has a reputation beyond repute996ttalot has a reputation beyond repute996ttalot has a reputation beyond repute996ttalot has a reputation beyond repute996ttalot has a reputation beyond repute996ttalot has a reputation beyond repute996ttalot has a reputation beyond repute996ttalot has a reputation beyond repute996ttalot has a reputation beyond repute
Okay well mine (996.t DME) is no where near correct using recorded engine load. For example load = 173, VE = 293. I have always thought this strange because I have seen logs for other cars where the actual engine load is higher than mine, but the hardware on the car is nowhere near mine. That is why I think VE is a better calculation. It supports what we know in terms of power that the cars are making.
Edited - okay I know the reason why - it is because the engine load calculated through durametrics will be wrong with the FORD MAF. That explains the difference to VE.
Old Jan 3, 2011 | 02:25 PM
996ttalot's Avatar
Okay another question thinking out of the box....if a non turbo car typically is around 100-130 VE, if we were to take say a standard Gallardo, surely this would mean that the figures are distorted? Or would the Gallardo have say 185 VE figure?
Old Jan 3, 2011 | 03:04 PM
The Bogg's Avatar
Hey Boggster, You might want to reconsider vtgs and go with a pair of alphas.
lol, probably true. But I'm really curious about how well the TPC/Proto 65mm version works. That's probably what I'll end up with. I would've bought them already but Todd seems awfully busy these days...
Old Jan 3, 2011 | 03:06 PM
TTdude's Avatar
Here's my calc VE vs LOAD for comparison (on a 997.1t). I'm seeing about a 10% differential at the higher end.
Old Jan 3, 2011 | 03:08 PM
TTdude's Avatar
I think he's holding out until you break down and get those alpha's...
Old Jan 3, 2011 | 03:11 PM
TiALSport's Avatar
TiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond repute
Jon
if you've dynoed your car and know the % loss on that dyno you can plot points as well for your MAF readings.
wa = hp (crank)* AFR * BSFC/60
wa = lb/min of actual air flow
1 lb/min air flow = 27.21 kg/hr (MAF in above equation)
Old Jan 3, 2011 | 03:15 PM
TTdude's Avatar
Cool, more equations. Thanks for posting. What values would you estimate for BSFC for 600-900 bHP P-turbo?
Old Jan 3, 2011 | 03:19 PM
TTdude's Avatar
Not quite following you Ken. What are distorted? Is it something more than just total displacement that you're asking?
Old Jan 3, 2011 | 03:20 PM
ttboost's Avatar
Could be some variables.. but .60 should be safe?
