Toyo Proxes RA-1 335-30-18
Old Jan 13, 2011 | 12:07 AM
Turbo Fanatic's Avatar
I've got a chance to pick up a set of Toyo Proxes RA-1s and am thinking the 335 would go well with my 12" OZ wheels coming from tire rack. They are almost 1" taller than the stock 295s and I would get front tires to match the diameter.
Anyone have experience with fit?
Also any opinions on this tire in general?
Old Jan 13, 2011 | 12:59 AM
f1crazydriver's Avatar
f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !
I have the same wheels, they wont fit. I have issues with 315's You will rub the plastic inner fender. Use your spacers or rub the helll out of hte plastic fender linear. Even then you may rub in the outside. I can't say I do but i'm running negative 2.5 camber so the top of the rim sits in. I would say max spacer so it wont rub with my camber would probably be a 5 mm . So I would say no to a 335 unless you are tom kerr and did some rear adjusting.
RA1's are awesome tires...very loud on the hwy but grip nice when they are up to temperatures. When cold and psm off, sideways action and you cant hear them breaking lose....well you don't hear screach even when up to temperature and when they break lose.
Old Jan 13, 2011 | 08:15 AM
LiNks's Avatar
LiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond repute
Do it!! and tell me how you made it happen so I can do it next! haha
titannero
May 20, 2016 08:12 AM
drug delivery
Oct 24, 2015 11:04 PM
Turbo3.6
Sep 18, 2015 11:10 AM
wastedyolk
Sep 17, 2015 11:57 AM
