Help - will 32mm lug bolts fit?
I just got a set of DPE S20's and found that the wheel locks won't fit. I wanted to use Rad locks but they come in a 28mm or 32mm shank not 30mm like the stock bolts. Will 32mm bolts fit without any spacers?
2mm longer should fit. but if you would like some piece of mind put the new lug in the rim measure how much protrudes and thread that amount into your hub and rotate by hand. the fronts are no problem but the rears have the E brake behind the hub. Hope this helps you.
