Someone Have this Yet???
Originally posted by red944
Has anyone measured the temp output on a turbo and a NA? Just curious if anyone had the fuel flow rates and air/fuel ratio of each also.
You have to look at this way, we already saved $110K when we didn't buy the 360CS. With this you get the Ferrari sound at the flick of switch and about 70lbs in weight savings. Another way to look at it is that it's about the cost of replacing a pair of PCCB rotors.
My concern with this thing is not the cost, but it will LIKELY trip the Check Engine Light and confuse the ECU with variable back pressure. In 360CS the computer knows that this thing is out there so it deals with it properly. I am hoping those brave individuals that try this unit will run a before/after dyno and report any problems with the CEL.
Originally posted by cjv
Trouble is, for alot less money you can rebuild your motor with a GT3 oil pump and Carrillo or Pauter rods.
Huh? I already have all that and a warranty too.
Originally posted by Hamann7
I like the burned Ti look, my issue is that the **** will crack with all the heat coming from the turbos.
Originally posted by Life Dies
With that kinda quality going into a product I am sure they have enough understanding of the materials they are working with. I doubt they will crack.
the kreis-sieg exhaust appears to have approx. 2in. exits from the cats aswell as from the muffler. you would loose hp for controllable sound for only 20gs.
consider fabspeed or europipe with wonderful quality and sound while producing the most additional power of any exhaust.
additionally
additionally
