CEL codes
Old Mar 4, 2011 | 02:37 PM
radgirl's Avatar
radgirl is infamous around these parts
CEL codes
My 2001 911tt just started throwing a P0491 and P0492 code. I have read in previous posts that this code can be due to a vacuum leak at the Combination valve for secondary air. I checked the connection and it seems fine. The car runs fantastic, but I have noticed fuel mileage getting progressively worse. I figure that is due to the lousy 91 octane oxygenated fuel here in Aurora,CO.
The only maintenance I have done to the car in the last few months was to replace the cabin air filter with an OEM part and change the engine air filter to a K&N.
Would any one of those possibly be the culprit for the codes? If not, any other troubleshooting ideas would be greatly appreciated.
Old Mar 4, 2011 | 02:49 PM
jpflip's Avatar
In your post you do not mention if you hear the air pump running...Engine compartment on the forward right side there is the air pump and this pump should start for few minutes after cold start...
Old Mar 4, 2011 | 04:13 PM
radgirl's Avatar
Had to let the car cool all the way....when I started it the air pump did run for a little less than a minute.
Old Mar 4, 2011 | 04:19 PM
jpflip's Avatar
The air leak we are talking about can be really minimum. Sometimes hard to hear or to feel. it can be from one of the lines on this drawing. These are sense line. May be one is disconnected. Very hard to see all of them....
BLKMGK
May 31, 2016 04:32 AM
intouch1
Sep 20, 2015 06:14 AM
Yogi911
Sep 9, 2015 08:20 PM
