Please HELP! Bonehead move.
Old Mar 5, 2011 | 04:45 PM
Talisman013's Avatar
Talisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond repute
Originally Posted by jpflip
Look at the fuse in the relay support #1 at location 27
I swapped 27 with another one, no go. Crank the car and see 12 volts, dips below 12 when I turn on the lights. I went to local Porche dealer to buy a known good relay, there computers were down and they couldnt sell me one until monday. I spoke with one of their mechanics, he said the battery bulb is actually part of the circuit, kind of like a fuse. So I headed home to check it, bulb is fine.
All of this because I didnt disconnect the battery. Grrrrr.
Old Mar 5, 2011 | 04:54 PM
jpflip's Avatar
I was thinking about your problem this afternoon. Did you check the voltage output like Adam was mentioning. When the engine is running put the positive probe of your voltmeter to the post under the black cap and the negative anywhere on the body where there is a good ground . If you have less than 14 volts, the alternator regulator is dead.... It is difficult to troubleshoot because something somewhere did not like the surge, but where....
Old Mar 5, 2011 | 05:35 PM
14.26 volts - car running
then walked to front of car and tested battery, 12.4 volts at battery while car is running.
Old Mar 5, 2011 | 05:41 PM
jpflip's Avatar
The alternator is obviously working properly. Good job Talisman. Where is a weak point...???? What is a battery bulb???
Old Mar 5, 2011 | 05:46 PM
He was referring to the bulb on the dash cluster, but its fine.
Old Mar 5, 2011 | 05:49 PM
jpflip's Avatar
It is a difficult one to trouble shoot ! Isn't it!
Old Mar 5, 2011 | 05:51 PM
So frustrating!! I need to be putting miles on the clutch, not doing this.
I do appreciate your assistance.
Old Mar 5, 2011 | 05:53 PM
Originally Posted by Elegant Performance
Where did you get the 14.26?
I assume you got the 12.4v between battery terminals while car was running?
Another thing to check is the ground wire from the battery. Check it for oxidation and a good connection at the battery and the other end.
Other thing you can do is get a long enough ground wire to your voltmeter and keep the same "good": ground for different check points, this will give you more consistent voltage readings and will help with deductive reasoning.
14.26 is from the + jumper point above alternator and ground lug near airbox.
Old Mar 5, 2011 | 06:02 PM
jpflip's Avatar
Do you have access to Durametric and if you do any faults???? Is there a system that is not working properly, lights, dash lights etc. Did you check your battery ground... See sheet 16 E2 of your wiring diagram for battery ground 17 c3...
Old Mar 5, 2011 | 06:22 PM
Everything seems to be working fine. I did not check battery ground, because I didnt think the car would even start with a bad battery ground.
I drove at least 50 miles before noticing the problem.
I dont have access to a durametric, I do have a Kiwi ODB2 wireless thingy and a couple of apps on my iphone that will show me codes, but wouldnt my dash show me something if there were a code that durametric would pick up?
Old Mar 5, 2011 | 07:33 PM
1. Charge the battery and check the ground.
2. See if you still have a problem.
Basics first.
Honestly, I don't think you would get far without the charging system working. Definitely not 50 miles far.
I will do this, but my previous battery was fully charged, and died after 50 miles. I replaced with a brand new battery because I didnt want to tow the car home to charge it.
Putting on the Ctek(very cool charger) now.
Old Mar 5, 2011 | 10:31 PM
tonka858's Avatar
tonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud of
Yea you can rule out the battery if it dies while driving.
Old Mar 8, 2011 | 11:37 PM
Did you ever figure it out?
Yes, I wanted to be sure so I put about 150 miles on it today.
So here is the sequence of events:
1. Didnt disconnect battery and sparked wire going to front of car.
2. Finished clutch job expecting car not to start, it started and drove fine for 50+ miles, then voltage dropped and car wouldnt crank.
3. Replaced battery to get the car home and troubleshoot.
4. Through 6speed research, I decided that the voltage regulator probably popped when I shorted the cable. I put a new alternator on(with new reg). Same problem
5. Checked every fuse and relay on the car.
6. Decided to trace the wire that shorted, so I put the car back on the lift, removed panels, look up at the starter.... hmmm, there was a nut there before...
I must have only hand tightened the nut holding the 2 cables on the started, which is why I got the initial 50 miles. It vibrated lose and stopped charging the battery. I put a new nut on and tightened it.
All is good.
Thanks to everyone for all of the help.
Old Mar 8, 2011 | 11:58 PM
atisvt99's Avatar
atisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant future
Awesome! It's a weird kind of relief to have a simple solution to an otherwise frustrating problem! haha
Old Mar 9, 2011 | 02:31 AM
jpflip's Avatar
Good news Talisman, congratulation!
Oct 6, 2015 06:13 PM
Trundle997
Ferrari
10
Aug 22, 2006 09:25 PM
JPanamera
Ferrari
Jun 1, 2006 03:31 PM
