Upgrade K16s Turbo - What DV Spring?
Old Apr 14, 2011 | 07:20 AM
vshugo996's Avatar
vshugo996 is a splendid one to beholdvshugo996 is a splendid one to beholdvshugo996 is a splendid one to beholdvshugo996 is a splendid one to beholdvshugo996 is a splendid one to beholdvshugo996 is a splendid one to beholdvshugo996 is a splendid one to behold
Hi,
I have installed a stock turbos (K16) and Forge Diverter Valves with the weak green spring.
I will go upgrade the turbos to K16/24 (K16s) with 1.1 bar, Ypipe, Plenum, exhaust, 997.2 RS intercoulers, ECU new program.
With this upgrade should I replace the DVs springs? What Colour?
Valve Spring color coding
Green - 5-15 PSI
Yellow - 15-23 PSI
Blue - 23-30 PSI
Red - 30 + PSI
Thanks,
Vitor S.
Old Apr 14, 2011 | 08:14 AM
ant_8u's Avatar
ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !
Don't think it's necessary to change the spring
My car is stock K16, and I'm using the yellow springs without issue
Old Apr 14, 2011 | 08:31 AM
vshugo996's Avatar
What mods has your car?
The turbos have the stock pressure (0.7 bar)?
Regards,
VS
Old Apr 14, 2011 | 11:01 AM
ant_8u's Avatar
I don't have any performance mods
My car is standard - just with Forge DVs and yellow springs
3WDistributing
31
Oct 27, 2017 01:26 PM
alevine
Nov 4, 2015 10:05 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
MadWhip
Sep 3, 2015 02:04 PM
Regent
Aug 21, 2015 11:14 AM
