Clutch question - Kevlar or Fiber Tough?
Old Apr 19, 2011 | 01:50 PM
johnspeed's Avatar
Originally Posted by vividracing
Johnspeed, not true
Tim941 - yes the Fiber Tough is strong like kevlar, just not as abrasive to the flywheel surface.
The pressure plates are modified to the same lbs pressure and both discs are sprung and in your pictures it was the same looking dics as their stage 2 Porsche one,and Louis said he made them the same way for you...thats all I am saying......
Old Apr 19, 2011 | 01:54 PM
johnspeed's Avatar
Originally Posted by Tim941NYC
Not sure what that part numbers is but the 999 plate is the one from sachs that has the most pressure. Milltek is good stuff, don't know why they are not used more.
Hi,Actually their are two 999 pressure plates,,,one has more pressure then the other....check out Sachs web page,not the racing one,OR FVD sells both 999s......
Old Apr 19, 2011 | 08:48 PM
Tim941NYC's Avatar
Originally Posted by johnspeed
From what I was told at CM,fiber tough is easier and faster to break in....and they said Porsche people prefer that because they do not want to spend a long time breaking it in????
Yup, plus glaze the Kevlar and trans is out and you pay the labor again
Old Apr 19, 2011 | 08:51 PM
Tim941NYC's Avatar
Its been a while since I played with the single disk set ups.. PM in bound.
Old Apr 20, 2011 | 05:06 AM
atisvt99's Avatar
atisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant future
Good thread...
I've been lead to believe that Clutchmasters uses Sachs disc and PP anyways... simply modified for more clamp force. Does anyone here know otherwise? I was looking at going with a Sachs setup for quite some time - and some of the higher HP guys said you can simply send the Sachs unit off (to Clutchmasters actually) to have them modify it for more bite... Upon asking CM about this process, they suggested that I just use their kit to begin with (not surprising from a sales perspective) since they are using original Sachs parts as a base to their kit anyways... Makes sense, yes?
I'm looking to get the CM Stage 3 (fibertough on both sides) with AI flywheel for my K24/20G + FULL supporting mods setup.
Old Apr 20, 2011 | 08:13 AM
johnspeed's Avatar
Hi,You are right,,they all start with Sachs and modify accordingly....CM can and will modify your stock set-up for a charge,,,they have done it on others.....
Old Apr 20, 2011 | 11:41 AM
Tim941NYC's Avatar
One of the 999 P-plates is thicker and can handle more heat before warping.
Jul 29, 2019 11:13 AM
Marcos AMV8
Dec 18, 2015 06:03 AM
The Oss
Aug 24, 2015 08:19 PM
pwdrhound
Aug 20, 2015 05:54 AM
