996TT - Install Pss10 without lower. Possible?
Old Apr 30, 2011 | 07:17 AM
vshugo996's Avatar
vshugo996 is a splendid one to beholdvshugo996 is a splendid one to beholdvshugo996 is a splendid one to beholdvshugo996 is a splendid one to beholdvshugo996 is a splendid one to beholdvshugo996 is a splendid one to beholdvshugo996 is a splendid one to behold
Hi,
I would like install a bilstein Pss10 coilover suspension but I canīt lower the car. My garage has a big ramp.
Itīs possible with the springs inclued in this kit?
Old Apr 30, 2011 | 10:38 AM
pumalex's Avatar
pumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond repute
yes i would beleive so as i lowered mine only about 3/4" and i still had room to go higher, not much lower though. In fact, i am pretty sure you could lift the car higher than stock with this suspension. The problem is if you want it really low, the adjustement is completly at the bottom in front i beleive (not sure, might be back though)
Old Apr 30, 2011 | 03:42 PM
coastalb55's Avatar
coastalb55 has a brilliant futurecoastalb55 has a brilliant futurecoastalb55 has a brilliant futurecoastalb55 has a brilliant futurecoastalb55 has a brilliant futurecoastalb55 has a brilliant futurecoastalb55 has a brilliant futurecoastalb55 has a brilliant futurecoastalb55 has a brilliant futurecoastalb55 has a brilliant futurecoastalb55 has a brilliant future
Read the specs for the PSS10. Bilstein says that "minimum" lowering is 1" front and rear.
I have KW V3 at their highest setting and they are still significantly lower than stock.
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
bmwtmx
Aug 26, 2015 07:26 AM
John@SpeedTech
Aug 23, 2015 12:07 AM
