Originally Posted by needforspeed502
(Post 3201822)
Im surprised that 4 of the rods were bent. How bent were they?
Originally Posted by OS Inspector
(Post 3201825)
im not have you seen what a stock 996tt rod is? its the same as the NA 993 rod
this has been happening over and over just no one has been talking about it. |
Originally Posted by landjet
(Post 3201716)
Chris, you mentioned raising the rev limiter to 7500rpm. When doing an engine build, how do you determine what is a safe rpm number for redline? What factors play into this determination? I know a number of tuners raise the rev limiter on stock cars when you buy their flash. Is that safe?
1 rod angle. 2 rods and rod bolts 3 weight of valve train. I run 8000 rpm redline but shift as soon as my torque peak is ideal for the next gear |
Originally Posted by Chris Green@USP
(Post 3201635)
Pistons and sleeves looked good wen they came out, and 4 out of 6 rods seemed to have started bending. I'll be keeping the stock oil pump and head studs. Raising the compression would be nice, but I wanted to keep this build pretty basic.. its usually the basic setups that end up doing the best :) . Thanks for the compliment on the head work, I'm really happy with the guys work as well. Yes, I changed to single groove keepers.
Happy Wednesday gentlemen! |
What about going from a dual mass flywheel to a LWFW, does that allow for safe higher rpm limits?
subscribed .. awsome
(Post 3202286)
Sorry, I'm not clear on what you mean. What is "pasty" temp? Also, if it depends on piston speed, wouldn't a LWFW allow for quicker piston speed?
(Post 3201635)
Originally Posted by P2P
(Post 3204037)
Your WHP would be similar to mine,not exactly because you have RWD and another variables. Rolando |
Looks like fun Chris, did Bill do that headwork ?
Actually i'm running stock injectors and my car is running lean. 1bar on Pump gas and RWD 470 hp. BTW my exhaust is catless.
(Post 3206043)
Thanks for your info man. |
Originally Posted by rdss
(Post 3206085)
I run 1.1 bar also from protomotive by Markski but i use a mixture 50/50 of 94 pump and 104 race leaded gas that's around 99 octane.I also have 5.0 FPR,stock injectors.
Thanks for your info man. Watch out |
(Post 3206108)
1.1 bar u may run out of ur injectors duty cycle and the motor will lean I think.
Watch out I understand that the 5 FPR does it.I hope they are right. |
