996TT .2 bar boost leak
Old Jul 2, 2011 | 02:35 PM
coolice232's Avatar
coolice232 is infamous around these parts
My 996 leaks boost , when i reach .2 i start hearing the boost damping out of the turbo as if the wastegate is open , is there any was to adjust the gates ?
Need help
Old Jul 2, 2011 | 03:13 PM
TT996-2002's Avatar
TT996-2002 is a jewel in the roughTT996-2002 is a jewel in the roughTT996-2002 is a jewel in the roughTT996-2002 is a jewel in the rough
The waste gates could be stuck open. They are spring loaded. U can feel it from the bottom on the side of the turbos. It takes some force to move them but they should move and spring closed.
These arms can break as well to the wastegates
If it's not that there is a major boost leak. Search the forums for a boost leak tester. Mine was in the f pipe and I could only get .6 bar
Old Jul 2, 2011 | 05:14 PM
raineycd's Avatar
+1 best to do a boost leak test and then check the wastegates and see when they start to open - both DIY are here if you do a search.
Rguy
Apr 12, 2020 11:11 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
sparks
Sep 8, 2015 03:03 PM
petron5000
Sep 6, 2015 11:20 AM
AdamNoone
Sep 3, 2015 04:15 PM
