So, Has Anybodys Car Ever Just Cut Out On Them?
Old Jul 17, 2011 | 05:08 AM
ant_8u's Avatar
ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !
Originally Posted by Sunnyside
.....If the car doesn't start then you need to get some codes with a Durametric. I got mine from here: http://www.hickleys.com/diagnostics/durametric.php
Thank mate, appreciate it
Old Jul 17, 2011 | 05:26 AM
Frank ( Sunnyside )'s Avatar
Frank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond repute
your welcome.
At the very least get your fuel pressure tested. that U bend pipe in the pump , due to the severity of the bend, and age, can and does split. This drops your fuel pressure.
I am surprised it doesnt attempt a kick when you try to start the car. With a split fuel hose there is a little pressure at the injectors, so the engine normally gets enought fuel to make it splutter
Presume you have checked the pump fuse and DME fuses ??
Codes would be a good thing to know as well.
Old Jul 17, 2011 | 06:23 AM
ant_8u's Avatar
Yeah, I've checked the fuses
I even pulled them all just to be doubly certain
The obc now tells me to check fuel level, but I'm guessing that's because I pulled the fuse
There's no spluttering or jumping at all, it just swings over
I don't actually expect anyone to be able to diagnose the fault without any codes
I thought I'd start the thread so it might be useful if this sort of thing happens to anybody else in the future
Unfortunately, when it comes to modern cars I'm an idiot
Give me some carbs and a distributor and I'm in my element
Old Jul 17, 2011 | 07:11 AM
This might sound a bit simple, but, have you had the battery disconnected lately, by which I mean before it broke down. I ask , because the fuel gauge is not like the old style of gauge. If you disconnect the battery with less than 1/2 a tank of fuel, it will not read correctly. The low level fuel light will not work either. So are you sure you have fuel in the car, irrespective of what the gauge says??
With less than 1/2 a tank of fuel the DME works out what is in the tank, it does not use the sender unit in the tank, it predicts the fuel level and moves the gauge in the dash accordingly.
Old Jul 17, 2011 | 09:33 AM
ant_8u's Avatar
Good info - thanks!
I haven't had the battery disconnected for a couple of months
I filled the car up with fuel last week
I don't do many miles, so a tank normally lasts me a month
The computer said ~150miles remaining when I stopped
I'm going to put a couple of jerry cans of fuel in though, that way I can eliminate that as a factor
Old Jul 17, 2011 | 03:12 PM
ant_8u's Avatar
I've composed a list of possibilities for my non-starting
I thought I'd do this incase my car doesn't throw any codes, and also in order to help other members in the future should the same thing happen to their cars
Here's my list so far;
Fuel Pump
DME Fuel Pump Relay
Coil Packs
Crank Sensor
Starter Motor
Ignition Switch
Any others I should add?
Old Jul 17, 2011 | 03:37 PM
Fuel Pump
DME Fuel Pump Relay
Coil Packs
Crank Sensor
Starter Motor
Ignition Switch
Fuel pump probable, get pressure checked.
DME Fuel pump relay possible, check relay and bypass to run pump.
Coil Packs, all 6 ....improbable.
Crank Sensor, never looked into that issue, but could be?
Starter motor , No as it turns over......doesn't it?? !!
Ignition switch, unlikely as they throw a lot more issues when they fail.
first.............codes
second........fuel pressure check or check pump & piping
third............pull a coil pack off and use an old plug held to the block to check for a spark.
You really do need to get some codes though.
Frank
Old Jul 17, 2011 | 03:39 PM
ant_8u's Avatar
Frank
Yeah, I'm ordering the durametric in the morning
Just messing around in the meantime
Old Jul 17, 2011 | 03:45 PM
Got your PM.
Keep ion touch,
Frank.
Old Jul 24, 2011 | 06:01 AM
ant_8u's Avatar
Ok guys, my durametric is on order, but I'm getting impatient
What checks can I do in the meantime whilst waiting for my durametric to arrive?
The car is on charge and has a full tank of petrol.....
Old Aug 21, 2011 | 03:05 AM
ant_8u's Avatar
OK Guys,
Can somebody tell me how to use my Durametric?
I think i'm doing it right, but nothing has shown up - just some errors for the alarm
I've got the car on charge - instrument cluster shows as 12 volts
Ignition turned on
Durametric plugged in
Click "Functions" in the top tab bar
Click "Short Test All Modules"
What else do I need to do?
Old Aug 21, 2011 | 03:27 AM
ant_8u's Avatar
Looks like I didn't check all the boxes before running the tests......
This time I've ticked the boxes for the ABS/PSM and the Instrument Cluster and have gotten the following.......
ABS/PSM 5.7
Current Fault Codes
5522:
DME: CAN message missing
4276:
Valve supply voltage
Instrument Cluster K21
Current Fault Codes
9110:
DME control unit
9111:
PSM/ABS control unit
Those codes have a red exclamation mark next to them
The central locking and alarm codes say they're for information purposes only, and have a yellow excalamation mark next to them
Should I clear the codes and then retry again, or would this cause more problems?
I'm using the Version 6 Beta software
Old Aug 21, 2011 | 04:27 AM
ABS/PSM 5.7
Current Fault Codes
5522:
4276:
Current Fault Codes
9110:
DME control unit
9111:
Fault code 5522
DME: CAN message missing 1
Diagnostic conditions
Engine running
No CAN message from the DME control module
Possible cause of fault
DME control module disconnected
CAN bus connection faulty
DME control module faulty
Affected terminals
Diagnosis/troubleshooting
Before troubleshooting, read out the fault memory of the DME control
module and eliminate any faults present.
Note!
Work instruction Display OK If not OK
1 Check CAN bus from DME
contol unit to PSM control
unit for open circuit
Switch off ignition
Pull plug off PSM control module
and Tiptronic control module
Measure resistance between
DME control module plug pin
D36 and PSM control module
plug pin 24
< 5
Ω
Step 2
Open circuit
between DME control
module pin D36
and PSM control
module pin 24
End
2 Check CAN bus from DME
D37 and PSM control module
plug pin 40
< 5
Ω
Step 3
Open circuit
between DME control
module pin D37
and PSM control
module pin 40
End
3 Replace DME control module
End
Fault code 4276
Valve relay
Actual values of solenoid valves are evaluated and display
implausible values
Valve relay does not pick up, drops out or sticks
Short circuit to ground or open circuit in circuit to control module
terminal 6
Fuse E9 faulty
Wire/ plug connection faulty
PSM hydraulic unit faulty
Affected terminals
Terminal 6
1 Check supply voltage of
the valve relay
Switch off ignition
Pull plug off the PSM control
module
Measure voltage between PSM
control module plug pin 6 and
ground
> 11 V
Step 2 Check following
components:
Fuse E9
Fuse F7
End
2 Replace hydraulic unit
End
911 Turbo (996)
9025 Fault code 9110
90-10
page 1
Instrument cluster K20
9110xk20
90
Printed in Germany – 8, 2001
90-10
Fault code 9110
DME control module
Ignition on
Short circuit between CAN-high and ground
Open circuit of CAN-high drive
Open circuit of CAN-low drive
The CAN drive bus is connected to the following control modules:
DME
Tiptronic
PSM and steering angle sensor
Instrument cluster
Affected terminals
Plug A, terminals 15 and 31
Note!
1 Read out DME fault memory
Read out DME fault memory and
remedy any stored faults
The fault is remedied
End
Step 2
2 Check CAN-high drive for
open circuit
Switch off ignition
Pull plug A off the instrument
cluster
Pull plug D off the DME control
module
plug A on the instrument cluster
pin 15 and plug D on DME control
module pin 36
< 5
Ω
Step 3
Repair wiring harness
End
911 Turbo (996)
9025 Fault code 9111
90-11
page 1
9111xk20
90
90-11
Fault code 9111
PSM/ABS control module *
Ignition on
Due to a faulty component, the PSM system has switched off or
PSM control module is faulty
DME
Tiptronic
Instrument cluster
Affected terminals
Note!
1 Read out PSM fault memory
Read out PSM fault memory and
End
Step 2
open circuit
Switch off ignition
cluster
Pull plug A off the PSM control
module
pin 15 and plug on PSM control
module pin 24
< 5
Ω
Step 3
End
Old Aug 21, 2011 | 12:01 PM
ant_8u's Avatar
Pardon?
Old Aug 21, 2011 | 01:14 PM
Pardon?
That's what your codes are and how to diagnose the problem taken form the Porsche POSES system. (Tech Manual)
I presume you posted your codes to be told what they mean
