Got a Durametric
Got a Durametric
I just got a Durametric..Going to try and figure out one last time, why my 996tt is idling a bit high, and giving me the check engine light before I take it to porsche on Friday. I installed the program and when I try to click on the Motronic (Engine DME) it tells me module failed to initialize. I assume thats the fuction that checks my engine?
Did you have the key in the ignition ? Turn the key one
click.
e-mail Owen Sutton at Durametric osutton@durametric.com; he is brilliant( top guy) and will talk you thorough any problems you have.
Keep us all updated.
Frank
OK.. Finally got my Durametric up and running on my computer.. Had taken my car to the Porsche dealer before I had it working and they informed me that I needed a new Air Mass Sensor. They cleared my check engine light and told me to order a new one online and install myself. Check engine light turned back on during the ride home. Instaled the new sensor and once the car warms up, the idle runs high. Unless I turn the A/C on, then it idles just fine. The Durmetric Gave me two fault codes:
Bosch Digital Motor Electronics Motronic 7.8 Turbo Module Identification
Porsche fault code 32 - Idle control at stop
[IMG]file:///C:/Program%20Files%20(x86)/Durametric%20Software%20Inc/Durametric%206/Data/HTML/redsmall.jpg[/IMG]P1133:
Porsche fault code 358 - Oxygen sensing adaption lower load range bank 2
PO507: Porsche Fault Code 32. Idle control stop.
P1133: Porsche Fault Code 358. Oxygen sensing adaption lower load range bank 2.
Wonder what I should try next...
[IMG]file:///C:/Program%20Files%20(x86)/Durametric%20Software%20Inc/Durametric%206/Data/HTML/info.jpg[/IMG]
Part Number 996.618.680.02Supplier Part Number 004156016020 Current Fault Codes[IMG]file:///C:/Program%20Files%20(x86)/Durametric%20Software%20Inc/Durametric%206/Data/HTML/red.jpg[/IMG]
[IMG]file:///C:/Program%20Files%20(x86)/Durametric%20Software%20Inc/Durametric%206/Data/HTML/redsmall.jpg[/IMG]P0507:Porsche fault code 32 - Idle control at stop
jdbaker
Sep 19, 2015 10:34 AM
bigeazy
Southwest
Sep 16, 2015 12:28 PM
arhim22
Sep 7, 2015 08:49 PM
