996t Ecu flash/intake/exhaust vs z06??
Old Aug 7, 2011 | 03:18 PM
MY996TT's Avatar
MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !
Raced a mod z06 before, not sure what he had. Too much traffic... Head to head from 60 to 110. Did only one pull.
Old Aug 7, 2011 | 03:25 PM
boca996tt's Avatar
boca996tt is just really niceboca996tt is just really niceboca996tt is just really niceboca996tt is just really nice
what was the result?
Old Aug 7, 2011 | 07:50 PM
MY996TT's Avatar
head to head... I called that a draw.
Old Aug 7, 2011 | 07:54 PM
ek9max's Avatar
ek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud of
And your mods?
Old Aug 7, 2011 | 07:59 PM
soloracer996TT's Avatar
soloracer996TT is infamous around these parts
Originally Posted by boca996tt
what # is high boost setting ? I know over 1 bar but what are the K16 billet's running 1.2 bar more? is this thru the tune or is it adjustable some how?
I believe around 1.5 bar with the appropriate fueling. The wastegate springs are set at 1 bar. The ECU controls it to go higher. With the water/meth installed I am supposed to get the high boost level normally. However, if I run out of meth or turn the meth off the system reverts to the "safe" tune of the wastegate spring only. That is how I understand it works.
Old Aug 7, 2011 | 10:53 PM
MY996TT's Avatar
Originally Posted by ek9max
And your mods?
My performance upgrades...
Evoms GT660 (older one with ball bearings GT2871)
Evoms 44.5mm header
Fabspeed Quiet
75mm plenum + 75mm TB + custom Y-pipe
Evoms Clubsports ICs
Evoms coil packs
Evoms light weight pulley
Evoms TCU upgrade to 7k rpm (Tip)
Wevo SS engine mount
PSS10s
The car dyno'd at 510hp to AWD before the TCU, coil packs, pulley, TB, Y-pipe (with a 70mm plenum) mods.
Old Aug 8, 2011 | 08:47 AM
rob.boost's Avatar
rob.boost has a reputation beyond reputerob.boost has a reputation beyond reputerob.boost has a reputation beyond reputerob.boost has a reputation beyond reputerob.boost has a reputation beyond reputerob.boost has a reputation beyond reputerob.boost has a reputation beyond reputerob.boost has a reputation beyond reputerob.boost has a reputation beyond reputerob.boost has a reputation beyond reputerob.boost has a reputation beyond repute
X50 car
70mm Exhaust
1bar tune
No dyno numbers.
Multiple runs, different starting speeds, same result every time by around 150mph it was dead even with a Z06.
Old Aug 8, 2011 | 10:09 AM
k-ore's Avatar
k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !
Originally Posted by rob.boost
X50 car
70mm Exhaust
1bar tune
No dyno numbers.
Every been to the track?
Old Aug 8, 2011 | 11:38 AM
Lennon31987's Avatar
Lennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond repute
does a 996tt with K16 billets beat a z06? I would think so,, but just asking
it depends...
[quote=Divexxtreme;3280122]It takes a skilled driver to extract all available acceleration from a Z06, even from a roll. Slow shifts, short shifts...they can all have an effect.
indeed. this is truth.
Originally Posted by soloracer996TT
Yes...even on the low boost tune (1 bar) I just pulled a newer Viper ACR. On the high boost tune it would be game over. I am at 3400 feet above sea level though.
i would have loved to see this run, a new viper ACR is 600/600 and is a FAST car.
Old Aug 9, 2011 | 12:12 PM
rob.boost's Avatar
Actually no, never been to the track with this car. Might have to go in the next few weeks when it is under 108 degrees.
Old Aug 10, 2011 | 10:10 AM
Vipers are like vette's, require skill to keep WOT, TALL TALL gears with alot of torque, i doubt 1.0 bar'd billet 16's pulled hard, and what speeds did you guys go to? THe car is geared to do way over 200 and is lighter than our 996's. Im hard pressed to believe this as I own a 996tt and my good friend has an 09 SRT 10
MrJoshua
American Muscle
Oct 6, 2015 06:43 AM
Oct 2, 2015 02:23 PM
MrJoshua
Nissan GTR
Sep 27, 2015 07:04 PM
