Battery Replacement - 30 lbs
Old Apr 20, 2005 | 03:48 PM
ColorChange's Avatar
ColorChange is infamous around these parts
OK, here are the final shots of my battery replacement. It saves over 30 lbs and drops the battery cg quite a bit. I used grommets going through the trunk wall so there should be no cable scraping sissues. I didn't want to go inside around the fuel tank so I ran the wires in front of it. I will tack those down, probably with velcro.
It is not easy to securely mount the battery in the stock compartment so this braket fits great in the car. I will bolt it through the trunk floor board.
The battery is a Odyssey 680, and yes I did cover the positive terminal.
Old Apr 20, 2005 | 03:56 PM
Joe Weinstein's Avatar
Good for you. It looks clean too. I have had one bad experience
with this brand of battery: I got one for one of my garage
queens, and kept it on a good bttery tender. Nevertheless it
died, and I found out too late that Odyssey batteries need a
special charger/maintainer. A normal one won't do... I am
getting a replacement Odyssey, and getting the charger.
Joe
Old Apr 20, 2005 | 04:02 PM
I agree. I have both the battery tender trickle charger (only good for maintenance charge3) but bought the battery tender (6 amp) that actually charges the battery.
Old Apr 20, 2005 | 04:24 PM
rockitman's Avatar
rockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond repute
how come it's not in the battery compartment.???looks sort of cobb job - no offense, mounting it in the trunk. A little fabrication and ingenuity mounts it where it should be...
I believe S-Cargo has a bracket for the Odyssey battery. Chad has it...
Old Apr 20, 2005 | 08:05 PM
quartermile's Avatar
Junior Member
quartermile has a spectacular aura aboutquartermile has a spectacular aura about
I agree with Rockitman ... looks very sloppy and dangerous too. Consider that you are doing this wiring right around the fuel tank. Here is how I did it on my GT3:
Old Apr 20, 2005 | 08:37 PM
cjv's Avatar
cjv
Moderator
Shut off switch, bottom mounting plate and battery maintainer wiring. That's it.
Old Apr 20, 2005 | 09:11 PM
HotRodGuy's Avatar
love the ghetto setup
I have you beat though
What do these batteries weigh in at? ARe they close to dyna-batts 13 lber?
Old Apr 21, 2005 | 09:35 AM
Quartermile: Sloppy? probably, Dangerous? Maybe in an nasty accident.
Chad? Did you maching your own plate or did you buy it somewhere? That looks nice.
Old Apr 21, 2005 | 10:12 AM
HotRodGuy's Avatar
If I remember right, Akkurat makes a kit for the battery replacement.
what's the weight of this new batt?
Old Apr 21, 2005 | 10:13 AM
15 lbs.
Old Apr 21, 2005 | 06:14 PM
cjv's Avatar
cjv
Moderator
The plate was machined and welded by S Car Go Racing.
Jul 29, 2019 11:13 AM
Jun 10, 2017 07:45 PM
DetomasoGTS74
Nov 11, 2015 09:01 AM
DSCOFF
Aug 23, 2015 01:22 PM
pwdrhound
Aug 20, 2015 05:54 AM
