need help with oil temp and pressure sensor
Old Aug 23, 2011 | 09:33 PM
coolice232's Avatar
coolice232 is infamous around these parts
hi guys i need help with the following
1-
p0197 Oil temperature
i changed the sensor and still its not working i cant know the oil level coz am getting engine is not worm massage , durametric is giving me this code again and again , i under stand it could be the harness or the DME(hopefully not) , how can i check the wiring ? i want to check if the wiring is ok
2-
4460 Pressure sensor
when i reach the speed of 50kilo/m i get PSM/ABS
how can i troubleshoot the system ?
thanks in advance
Old Aug 25, 2011 | 12:06 AM
coolice232's Avatar
Up up up i need help
Old Aug 25, 2011 | 02:27 AM
coolice232's Avatar
i still cant ready my oil level becoz of the oil temp sensor , i changed the sensor and am still getting the same Code.
how can i check if the wiring is good ? if i remove the swtich from the sensor should i get different code ? does that prove a good wiring ?
Fester
Sep 8, 2015 09:35 AM
ECS Tuning - VW
Sep 2, 2015 01:47 PM
ECS Tuning - VW
Sep 2, 2015 01:19 PM
ECS Tuning - VW
Sep 2, 2015 12:58 PM
m_motorsport
Sep 2, 2015 12:53 PM
