Testing Rear Wing Operation - Off The Car
I've removed my rear wing due to minimal operation caused by a leaking ram(s)
I've refilled the pump and hooked everything up to a battery to test it's operation The left side now rises and retracts fully, but the right side doesn't move at all Could this be because the microswitches aren't fitted, or is there something else at fault? |
To answer my own question.......
It's not because the microswitches aren't fitted After running the spoiler up and down a few times the fluid in the right hand ram settled to a lower level again I topped it up a few more times and all seems to be well again :) |
Glad you got to fix it.
Thanks mate - there's loads of good info on here so I won't waste space listing what I did - I only copied what others have done previously
Next job is drivers window regulator! |
Originally Posted by ant_8u
(Post 3312599)
Next job is drivers window regulator! Do you mind posting the links here so that it's all contained in one thread? Thanks! |
Awesome! Thanks! Bookmarked!
No worries :)
Also - A few people have said you can hook a battery up to the spoiler motor in order to raise it, and that by switching the polarity around you can then lower it Just incase anybody needs to know which way around does what......... The rear-most terminal on the spoiler motor is slightly larger than the front-most terminal If you connect the positive charge to the rear/bigger terminal you will raise the spoiler If you connect the positive charge to the front/smaller terminal you will lower the spoiler |
Just to clarify, don't leave the connectors for the battery on the motor and the motor running!! I left similar instructions up on another thread and I guess someone left them attached and blew out the motor or the plunger. Just use common sense! :)
Originally Posted by D_Nyholm
(Post 3313654)
Excellent point - Massively important!! When on the car, the spoiler motor is cut-out by the microswitches BUT, when hooked up to a battery there is no auto cut-out The motor will continue to run even though the wing is fully retracted or extended Failure to disconnect the motor from the battery will cause the motor to try any continue it's operation and will lead to broken parts Take care |
(Post 3313666)
(Post 3313666)
When on the car, the spoiler motor is cut-out by the microswitches BUT, when hooked up to a battery there is no auto cut-out The motor will continue to run even though the wing is fully retracted or extended Failure to disconnect the motor from the battery will cause the motor to try any continue it's operation and will lead to broken parts Take care Let us know how long your spoiler lasts with fluids replaced. It would be interesting to see how long you can prolong the life of the spoiler by doing this. I just noticed my driver side ram is leaking but it is still working fine for now. I may convert to manual and not deal with it. Thanks! B |
I'll update the thread if/when my spoiler begins to fail again
I drained all the original fluid (as there's not very much in the system at all) and replaced it with some 'Slick 50' power steering fluid I've recently seen an Aero kit for sale I'm not sure whether to buy that as a possible back-up What do you think? |
(Post 3317417)
I drained all the original fluid (as there's not very much in the system at all) and replaced it with some 'Slick 50' power steering fluid I've recently seen an Aero kit for sale I'm not sure whether to buy that as a possible back-up What do you think? I look at it the same way as the clutch accumulator to GT2 slave upgrade. For me, if the part is prone to early failure, then if another solution presents itself that is affordable and improves on performance than it's a no-brainer to go ahead. In this case, the manual kit is affordable, cost way less than even a used set of hyrdaulics, and will most likely not fail again. The drawbacks are that I need to manually set the spoiler height and it won't go up or down at a certain speed. So, the "trick" factor is lost in the manual solution which for some, is an important characteristic of the Turbo. For me, that "trick" factor is not worth the cost. Furthermore, both the GT2 and GT3 have fixed wing designs so there really is no benefit except that it distinguishes itself as a Turbo model. Again, not worth the headache and cost to service/replace a known part that will fail at some point in time. Those are my thoughts. Brent |
Update - It's failed hilarious
I refitted the spoiler, and mechanism today Once fitted I operated the spoiler via the interior button It goes up and down as it should, but I noticed a small leak coming from one of the rams I'm not sure why this leak has reappeared, but I'm working on it Before I refitted the system I operated it quite a few times to make sure everything worked, and that it extended and retracted evenly Once I'd ascertained this I left the rams in the extended position (still off the car) My reasoning for this was that this is when the rams are under most pressure and are full of fluid (when the rams are retracted they're pretty much empty) With the rams extended I left them for a couple of days to check for leaks Everything was fine, so I refitted everything to the car today After a few operations it leaked slightly again :( I've operated the system quite a few times whilst fitted to the car I've cleaned up the leak, and have left the spoiler raised I've left it raised in the hope that the 'leak stop' in the fluid will do it's job (as the ram is full when in the extended position) I'll leave it for a couple of days, after which time I'll operate it again I'm guessing I may need to top the system up again at that time, and hope that the 'leak stop' will have done it's job by then More updates to follow |
