Why PSM/ABS lights were on?
Old Apr 28, 2005 | 02:48 PM
jaewoo0's Avatar
jaewoo0 is infamous around these parts
Lightbulb Why PSM/ABS lights were on?
I just got a call from my dealer shop.
PSM, ABS lights were on because oil got into a MAF(?) and it made sensor to cause fault.
the new filter had too much oil on it.
so what is a solution? don't know.
next time I change or clean-up my filter, shouldn't oil it too much.
anyways I'm picking up my car now excited.
Old Apr 28, 2005 | 02:56 PM
rockitman's Avatar
rockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond repute
wrap the new filter if it's a K&N or BMC with news paper and lie the filter on the ground with a phone book or the like weighting it down. Leave one day, then repeat process on the other side. Any excess residual oil should be soaked up by the news paper.
Was it a new filter or one you re-charged by oiling it yourself?
Old Apr 28, 2005 | 04:46 PM
jaewoo0's Avatar
It was a new cone filter.
Old Apr 29, 2005 | 07:15 AM
NC Bob's Avatar
NC Bob is infamous around these parts
Hopefully not the cone filter from the new EVO intake?
Old Apr 29, 2005 | 07:24 AM
PorschePhd's Avatar
The cone filters are made with the MAF in mind. Therefore the oil in the filters is drastically reduced. The filters shouldn't be an issue since the filters are hardly oiled.
Old Apr 29, 2005 | 09:31 AM
jaewoo0's Avatar
CAUSE: FAULT CODE:P0102 - HOT FILM AIR MASS METER
ROUGH IDLE & HESTATION UNDER PARTIAL LOAD
CORRECTION: READ & PRINT FAULT;COMPLETED FAULT CODE DIAG.; REPLACED AIR MASS METER; CLEAR FAULT;ROAD TEST;FUEL PRESSURE TEST
AuZZie
Sep 2, 2015 04:26 PM
Airbus Driver
Cayenne 958
Sep 2, 2015 12:50 AM
GSR Autosport
Aug 26, 2015 05:20 PM
