'04tt 265/35-18 fitment
Re: '04tt 265/35-18 fitment
Originally posted by ColorChange
OK, Here is where I am at. I am trying to get the fronts to last a little longer and remove some more understeer by going to wider fronts compared to my current 235/35-18 PS2's on I-forged rims to Fikse 265/35-18 MPSC's. ...Have I missed anything big?
Are you running a track-specific splitter?
Going to wider rubber to make them last longer--will you need to increase downforce up front to get enough heat in the tire to cut down on the push, and then will it realistically last more than the 235 or 245 options?
Cary probably has some interesting input for this problem. Cary, you out there?
Originally posted by tri7even
what size are the wheels? they are custom wheels, iforged should have made them with the right offset...it shouldn't rub like that and you shouldn't have to buy spacers period. that's the reason for custom made wheels...or am i missing something?
Originally posted by RWDRIFTC2
The rim is a 8.5 meant to hold a 235 tire. When you switch the tire to a 265 width, the rim sizes needs to go up, or you have to have a wheel that is made with the correct offset to hold the 265 and fit your car. Stock turbos can fit a maximum 245 tire up in the front. You can go wider with fender modifcations.
From my experiences wider rubber up front definatly made it "tighter" with all other setting being the same. Especially if your trying to make the tires last as Color Change has mentioned I would think that the camber would be stock to minimal. Which would increase understeer.
Super D: Yes, I have a track splitter. Also, with 600+ ponies, getting the tires up to temp is not hard. I have real time trire monitoring and brake caliper montiroing on the car now.
I have 9.5 or 10's up front, can't remember.
Oak: What makes you think the bigger tires will increase understeer?
Could be just the way I had interpret the increase in "tightness" which to me feels like increase with the wider rubber, I preferred how the turbo feels with an increase the neg camber to around -1.5 or maxed with the 235's MPSC. Feels much looser in quicker turn in's with less resistance, feels like less understeer esp on quicker and tighter turns.
Originally posted by oak
cjv, I believe you can now custom order any offset through Fikse. Orginally they only offered on 1/2" increments.
My bad. I was refering to wheel width.
The 265's are a great aid in eliminating the pushing and shoveling. You need to have at least a 9.0 or 9.5" inch wheel with this size tire. We have found that a slightly oversizes wheel, 12.5 on MPSC 315-18's in the rear induces less tire wall roll and makes the car respond with more understeer.
My camber is set about -2.0 up front.
Super D: I have real time trire monitoring and brake caliper montiroing on the car now.
Originally posted by cjv
Oak,
One of the ways you can correct understeer is by going to larger tires up front.
Oak,
Originally posted by PMac
Chad, I have read that wider tires up front gives more grip at the expense of 'feel' through the steering wheel. Have you found that to be true, or are your suspension upgrades sufficient that your steering feel is all "princess and the pea"?
Not really sure how to answer your question. The awd, in my experience, has better grip when properly setup. As for "feel", the feel on KA as it relates to the front suspension isn't really much different than the feel on a stock turbo. The difference is grip .......... less pushing, shoveling and roll.
The tires are not a magic pill by themselves. Wider tires, wheels and track. GT2 parts along with a custom wheel carriers, JRZ four way adj. race shocks, monoballs, approx 850 pound springs and a stiffer/lighter front makes for good response on anything but very tight turns.
The down side is she drives like a truck or race car.
Definitely not for long trips.
